mbazzano88 Posted May 22, 2012 Share Posted May 22, 2012 I recently ordered a catless UP, catted DP, and cat back. I'll be getting them installed and tuned at EFI logics in about a month, and the more I read up the more I worry that I will be blowing the end tanks off my stocker tmic. I'm on a budget right now, what would be the best and most cost effective way to keep from blowing up under stage two power? I'm not really worried about trying to get more power by adding a bigger more efficient tmic, I just want it to run safely. Thanks guys Link to comment Share on other sites More sharing options...
goneskiian Posted May 22, 2012 Share Posted May 22, 2012 You can keep your stock intercooler. You've got 2 choices: Bullet Proof Mod or JB Weld Mod. Cheers! Link to comment Share on other sites More sharing options...
scoobyscoodle Posted May 22, 2012 Share Posted May 22, 2012 JB weld is pretty strong stuff, it will easily handle stage 2 psi levels. Link to comment Share on other sites More sharing options...
OutbackXT05 Posted May 22, 2012 Share Posted May 22, 2012 Ive also seen some just use a big ring clamp around the whole tmic too and it worked fine. Link to comment Share on other sites More sharing options...
mbazzano88 Posted May 23, 2012 Author Share Posted May 23, 2012 Thanks for the suggestions, on the JB weld method they were saying it develops cracks rather quickly so I think I will attempt the bullet proof or large ring clamp method. Are there any other weak points that frequently fail with the added power? Link to comment Share on other sites More sharing options...
scoobyscoodle Posted May 23, 2012 Share Posted May 23, 2012 You are going to want to zip tie or hose clamp every map line. ESP the ones off that blue T connector under the tmic. Link to comment Share on other sites More sharing options...
