Low Clutch Pedal
First make sure your clutch fluid level is good if it's low you could have sucked air into the system if that's the case Try bleeding your system if that doesn't work replace your master cylinder and your slave cylinder (also called release cylinder in the cars Manuel) and it's also wise to replace them both at the same time
