stevo0525GT Posted March 1, 2013 Share Posted March 1, 2013 So I was installing new headers on my 05 legacy gt and a piece of threading where manifold attaches to heads cracked off so there is no way to put a new bolt in and secure the headers on tightly. I was curious what would be needed to be done. Would I need to goto a machine shop to weld on new threading? Link to comment Share on other sites More sharing options...
Indiglow Posted March 1, 2013 Share Posted March 1, 2013 what header is it? post a pic Link to comment Share on other sites More sharing options...
stevo0525GT Posted March 1, 2013 Author Share Posted March 1, 2013 I will when I'm home. But it's where the manifold attaches to the block. Link to comment Share on other sites More sharing options...
Indiglow Posted March 1, 2013 Share Posted March 1, 2013 what....header....is....it oem? Link to comment Share on other sites More sharing options...
stevo0525GT Posted March 1, 2013 Author Share Posted March 1, 2013 Oh. Ha sorry borla headers but its not on the headers it's the block Link to comment Share on other sites More sharing options...
Indiglow Posted March 1, 2013 Share Posted March 1, 2013 so the head is cracked/chipped? or just the stud is pulled out? Link to comment Share on other sites More sharing options...
stevo0525GT Posted March 1, 2013 Author Share Posted March 1, 2013 The place where the stud threads in chipped and fell off so the stud has nowhere to thread into Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 2, 2013 Share Posted March 2, 2013 The place where the stud threads in chipped and fell off so the stud has nowhere to thread into Thats not too terrible you may be able to re-thread the existing hole to the stock stud size if that fails you can use a heli-coil. Link to comment Share on other sites More sharing options...
stevo0525GT Posted March 3, 2013 Author Share Posted March 3, 2013 Well that would require drilling into the cylinder heads.! Which I'd rather not do ha. I was thinkin I could get someone to weld the old chunk of the threading back on and if that would hold. B/c also of I did the helicoil the exhaust still wouldn't sit right cuz it is still missing that huge chunk Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted March 4, 2013 I Donated Too Share Posted March 4, 2013 What on earth did you do?!!!? Welding may be a rough way to resolve this on the car and depending on the damage may not be that effective, it's not like you can weld the backside. Can you take pictures and show us? Link to comment Share on other sites More sharing options...
stevo0525GT Posted March 6, 2013 Author Share Posted March 6, 2013 Haha I didn't do anything it just cracked and there was no bolt there haha. But I took it to a friend who owns an exhaust shop who is really good at welding and he said it wouldn't be that effective b/c it's aluminum so I think I am going to have to replace the heads altogether.... Any thoughts? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 6, 2013 Share Posted March 6, 2013 Wow all these day's and know one has used the correct terms. You broke the stud off. You well need to find a good repair shop and hopefully have them use a easy out to remove the rest of the stud. They may need to put a insert in there for the new stud. I guessing you didn't use any PB Blaster before you did this. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ctlex Posted March 6, 2013 Share Posted March 6, 2013 the best way is to drill it out,tap it, and insert a heli-coil Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted March 6, 2013 I Donated Too Share Posted March 6, 2013 Max you think he just snapped the stud? With no pictures we can't be sure but he sure sounds like it's more than just the stud... ???? Exhaust shop has no tig welder? But yes, the heads being replaced is a better long term fix IF this is far more than just the stud. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 6, 2013 Share Posted March 6, 2013 the best way is to drill it out,tap it, and insert a heli-coil Right that's what the fix will be. Max you think he just snapped the stud? With no pictures we can't be sure but he sure sounds like it's more than just the stud... ???? Exhaust shop has no tig welder? But yes, the heads being replaced is a better long term fix IF this is far more than just the stud. I can't believe the head is cracked there from just removing the manifold, even if the stud broke. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
stevo0525GT Posted March 10, 2013 Author Share Posted March 10, 2013 I found a new tig welder so this should be done by Monday!!! Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted March 10, 2013 I Donated Too Share Posted March 10, 2013 Can you take pics of the damage before you do? I'm with Max C and can't believe you broke out a piece of the head... Link to comment Share on other sites More sharing options...
stevo0525GT Posted March 10, 2013 Author Share Posted March 10, 2013 Yes I will send a pic of the broken piece soon Link to comment Share on other sites More sharing options...
Enyce05LGT Posted October 7, 2018 Share Posted October 7, 2018 Can anyone help me ? Ive change my stock headers on my legacy 2005 gt and got The brand Manzo performance headers so they came with gaskets and bolts when i went to put them on the gaskets were poor quality and the bolts didnt even fit so my dumbass mechanic did what he does the best put some random ass bolt and messed up the threads so ive been try to find a solution i heard try the Time inserts and i did and its still leaking could it be headers are poor quality or just poor job ? Link to comment Share on other sites More sharing options...
rhino6303 Posted October 7, 2018 Share Posted October 7, 2018 Can anyone help me ? Ive change my stock headers on my legacy 2005 gt and got The brand Manzo performance headers so they came with gaskets and bolts when i went to put them on the gaskets were poor quality and the bolts didnt even fit so my dumbass mechanic did what he does the best put some random ass bolt and messed up the threads so ive been try to find a solution i heard try the Time inserts and i did and its still leaking could it be headers are poor quality or just poor job ?Headers are sub-par quality and flanges aren't flat. Keep OEM exhaust manifold or buy a quality header. Link to comment Share on other sites More sharing options...
Enyce05LGT Posted October 10, 2018 Share Posted October 10, 2018 Thank you rhino6303 that makes so much sense poor quality product !! Link to comment Share on other sites More sharing options...
