HNUTZ Posted December 1, 2013 Share Posted December 1, 2013 First time Subi owner 2005 Legacy wagon (non-GT) Suspension is toast: There does not appear to be many options for struts/shocks. Monroe/KYB 1. Can anyone recommend a strut/shock package for improved ride? I'm not racing so Koni's are more $$$ than I want to spend. May not fit anyway. 2. The KYB kit online: Fronts KYB G2R p#339097 and 96 Rears 341353. Can anyone confirm this is correct for non GT's 3. Should go ahead with strut mounts as well? thanks for the help Link to comment Share on other sites More sharing options...
Collin9338 Posted December 3, 2013 Share Posted December 3, 2013 i second this my front right stock strut just blew. I'm just going to assume that i need new strut mounts because the bolt that holds it in through the engine bay is nowhere to be found and the rod is just bobbling around... Link to comment Share on other sites More sharing options...
Nrw Posted December 3, 2013 Share Posted December 3, 2013 Konis.. Link to comment Share on other sites More sharing options...
Collin9338 Posted December 3, 2013 Share Posted December 3, 2013 Konis.. Well ya see the thing with that was I asked what you think about kyb'S not what you think I should get. Link to comment Share on other sites More sharing options...
ras06LGT Posted December 3, 2013 Share Posted December 3, 2013 KYBs are a good replacement for OEM. They won't really offer a performance upgrade compared to more expensive options, but for a stock replacement they are good. I plan to replace my struts with a KYB set this winter. The part numbers you show above are correct. Depending on the condition of the front strut mount bearings, you may consider replacing them as well (or just replace them to be on the safe side). Link to comment Share on other sites More sharing options...
Nrw Posted December 3, 2013 Share Posted December 3, 2013 Well ya see the thing with that was I asked what you think about kyb'S not what you think I should get. Well Konis do exactly what you want, improve ride and performance. KYB's are essentially stock replacements, so they will ride and perform like stock. Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 3, 2013 Share Posted December 3, 2013 To maintain the factory type of ride and handling, the KYB is where you want to go. These are a basic direct OE replacement of what came as standard on your vehicle. If possible, get them as a "quickstrut" setup that comes with new springs and strut tops and you'll eliminate any kind of issue that can be expected if you don't replace all of those parts. If you don't decide to do the above, you will ALWAYS want to change the strut tops for sure. As for the expense, it's absolutely worth it because it simply eliminates the possibility of an issue that can come up 2K or 20K later by using the old parts, but it will come up with clunking, rattling, and looseness in the front steering. Because you will need an alignment after replacing the struts, if it decides to rear it's ugly head at 2K, then you've wasted the money. You should also do a thorough inspection of lower control arm bushings and sway bar end links and clamp bushings. These parts can also cause suspension noise and looseness and are easily changed. To not inspect them and find out 5K after you've done the struts, is, again, wasted money on the alignment and labor because you'll need to do all of these things again. In the case of the lower control arm bushings, your absolute best bet IS to use a performance part as the Subaru stock pieces (affectionately known as "tennis balls") are not good. Whiteline makes the best option for the LCA bushings and is definitely worth the money and time to install. They will eliminate clunks and vague steering feel and tire wear as well as giving additional adjustment for alignment in the caster department. Sway bar end links and clamp bushings can be changed without affecting alignment and are fairly easily done if you've some mechanical ability. If you are tight on budget, you can wait for a bit after the installation of the struts/shocks but remember that these can make noise if they're bad and if the struts and shocks are bad, chances are good that these are also on their way out. Moog endlinks are a good replacement for both the front and rear sway bars and are readily available at a plethora of automotive parts stores. Clamp bushings are available too, but again, in this case, it's better to use a performance (polyurethane) part as they will last substantially longer and your car will be improved drastically in handling and overall feel. Plus, the polyurethane bushings (available from a number of sources-Prothane, Energy Suspension, Whiteline, AVO, and others-you simply measure the diameter of the sway bar and find a high performance/speed shop and they should have something that would fit) are generally less expensive than the OE Subaru bushings. Don't forget the rear sway bar for the bushings and end links too. These can easily generate clunking noise and rattles that are very difficult to find as they echo throughout the car and can sound like they're coming from anywhere and everywhere. These part replacements and alignment will make your car better than it was when it was new and not break the bank. The LCA bushings are VERY important because if they fail, they can cause a crash. If you can find the KYB as quickstruts, it saves a LOT of time and grief in installation, especially if you're doing it yourself AND it brings all of the spring rates back to new and stock. Good luck. Link to comment Share on other sites More sharing options...
HNUTZ Posted December 4, 2013 Author Share Posted December 4, 2013 Thanks for all the feedback. It's good to know what I should be looking for on bushings, struts etc, and what brands work better. So far, I love the car, but just need to get the suspension back par. I have searched for the quickstrut assembly, but can't find them for legacy. Unless someone knows where to find, I'm assuming they don't exist for this car. Too bad though, that would save time for sure. thanks again Link to comment Share on other sites More sharing options...
Collin9338 Posted December 6, 2013 Share Posted December 6, 2013 To maintain the factory type of ride and handling, the KYB is where you want to go. These are a basic direct OE replacement of what came as standard on your vehicle. If possible, get them as a "quickstrut" setup that comes with new springs and strut tops and you'll eliminate any kind of issue that can be expected if you don't replace all of those parts. If you don't decide to do the above, you will ALWAYS want to change the strut tops for sure. As for the expense, it's absolutely worth it because it simply eliminates the possibility of an issue that can come up 2K or 20K later by using the old parts, but it will come up with clunking, rattling, and looseness in the front steering. Because you will need an alignment after replacing the struts, if it decides to rear it's ugly head at 2K, then you've wasted the money. You should also do a thorough inspection of lower control arm bushings and sway bar end links and clamp bushings. These parts can also cause suspension noise and looseness and are easily changed. To not inspect them and find out 5K after you've done the struts, is, again, wasted money on the alignment and labor because you'll need to do all of these things again. In the case of the lower control arm bushings, your absolute best bet IS to use a performance part as the Subaru stock pieces (affectionately known as "tennis balls") are not good. Whiteline makes the best option for the LCA bushings and is definitely worth the money and time to install. They will eliminate clunks and vague steering feel and tire wear as well as giving additional adjustment for alignment in the caster department. Sway bar end links and clamp bushings can be changed without affecting alignment and are fairly easily done if you've some mechanical ability. If you are tight on budget, you can wait for a bit after the installation of the struts/shocks but remember that these can make noise if they're bad and if the struts and shocks are bad, chances are good that these are also on their way out. Moog endlinks are a good replacement for both the front and rear sway bars and are readily available at a plethora of automotive parts stores. Clamp bushings are available too, but again, in this case, it's better to use a performance (polyurethane) part as they will last substantially longer and your car will be improved drastically in handling and overall feel. Plus, the polyurethane bushings (available from a number of sources-Prothane, Energy Suspension, Whiteline, AVO, and others-you simply measure the diameter of the sway bar and find a high performance/speed shop and they should have something that would fit) are generally less expensive than the OE Subaru bushings. Don't forget the rear sway bar for the bushings and end links too. These can easily generate clunking noise and rattles that are very difficult to find as they echo throughout the car and can sound like they're coming from anywhere and everywhere. These part replacements and alignment will make your car better than it was when it was new and not break the bank. The LCA bushings are VERY important because if they fail, they can cause a crash. If you can find the KYB as quickstruts, it saves a LOT of time and grief in installation, especially if you're doing it yourself AND it brings all of the spring rates back to new and stock. Good luck. i really appreciate this. first things first tho gotta get these struts on and now i have to order the mounts for the front. I'm having horrible noises pretty sure the top bolt snapped and fell out. and I'm using lowering springs on the kyb's as that is what i currently have on my car Link to comment Share on other sites More sharing options...
