downtoearth Posted September 2, 2012 Share Posted September 2, 2012 this has been happening for a while now, ever since i got my clutch replaced because of a bad TOB when ever the clutch is let out a creaking noise is heard from the tranny engine area of the vehicle, almost like your stepping of a creaky wooden floor. it seems that when any amount of torque is applied to the transmission it creaks. could this be a symptom of a bad tranny mount, or engine mount or is the end insight? any other idea? 5mt NA Leggy 64,000 miles around 14,000 on the clutch Link to comment Share on other sites More sharing options...
ericem Posted September 4, 2012 Share Posted September 4, 2012 Sounds like throw out bearing you might be able to pull back the boot and spray some lubricant like lithium grease straight down on the sleeve of the transmission and on the clutch fork itself. When they replaced the clutch they probably didn't lubricate the clutch fork and center of the transmission where the TOB rides. Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 4, 2012 Share Posted September 4, 2012 It is typically not advisable to spray lubricant towards your clutch disc. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
downtoearth Posted September 4, 2012 Author Share Posted September 4, 2012 Sounds like throw out bearing you might be able to pull back the boot and spray some lubricant like lithium grease straight down on the sleeve of the transmission and on the clutch fork itself. When they replaced the clutch they probably didn't lubricate the clutch fork and center of the transmission where the TOB rides. i will come up with some way to apply it in a controlled fashion. but yes, i will avoid the clutch disc if i choose to go that route. i'm glad to see you don't think my tranny is gonna fall out one day. Link to comment Share on other sites More sharing options...
Brett Posted September 4, 2012 Share Posted September 4, 2012 It is typically not advisable to spray lubricant towards your clutch disc. hey BAC, my tranny sounds rough, but it feels smooth, aside from the slow roll in 1st gear where it's jumpy when you let off the throttle. is this common in a 5mt? Link to comment Share on other sites More sharing options...
Brett Posted September 4, 2012 Share Posted September 4, 2012 @downtoearth i don't mean to jack your thread or anything, but i guess it would be helpful to you too. Link to comment Share on other sites More sharing options...
downtoearth Posted September 4, 2012 Author Share Posted September 4, 2012 not a problem, wasn't getting much attention anyways Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 4, 2012 Share Posted September 4, 2012 hey BAC, my tranny sounds rough, but it feels smooth, aside from the slow roll in 1st gear where it's jumpy when you let off the throttle. is this common in a 5mt? Totally normal for a Subaru. Stiffer motor/trans mounts help reduce the jerkiness, but it's caused partially by engine management. There have been some that have tuned it out, though. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Brett Posted September 4, 2012 Share Posted September 4, 2012 alright, thats what i guessed. this guy at my work has a new wrx and he tells me that he thinks he has a bad tranny. especially during 5th also. he's even considering trading it in for a honda. i'll let him know about what you said. thanks Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 4, 2012 Share Posted September 4, 2012 Yep. Subaru's have been doing that for the whole 23 year history of the EJ engine. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Max Capacity Posted September 4, 2012 Share Posted September 4, 2012 What, a Subaru 5mt that sounds like a bucket of rocks when you lift off the gas...why I never hear mine when I have the radio turned up to about 14. Hence why I coast a lot on the back roads 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted September 4, 2012 Share Posted September 4, 2012 downtoearth, this type of sound is also heard from the clutch pedel itself. Underneath the dash were the clutch rod goes through the firewall is a spring. I would get this occasionally and putting some lube around this spring and it's contact points to help reduce the noise. Check to see if this sound is coming from the firewall underneath the dash. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
downtoearth Posted September 5, 2012 Author Share Posted September 5, 2012 here is some audio good examples are :49 :52 1:14 1:21 [ame=http://www.youtube.com/watch?v=E67_P9nkECA]http://www.youtube.com/watch?v=E67_P9nkECA[/ame] Link to comment Share on other sites More sharing options...
Bonafide P Posted September 5, 2012 Share Posted September 5, 2012 I hear that in my 08 gt too! It gets so annoying! Don't know what it is! Hopefully our trannys are okay! Link to comment Share on other sites More sharing options...
downtoearth Posted September 5, 2012 Author Share Posted September 5, 2012 I hear that in my 08 gt too! It gets so annoying! Don't know what it is! Hopefully our trannys are okay! Did it start after any work on your transmission? Link to comment Share on other sites More sharing options...
Bonafide P Posted September 5, 2012 Share Posted September 5, 2012 not sure about the previous owner but none since I bought it, at 68k now it's at 95k Link to comment Share on other sites More sharing options...
downtoearth Posted September 7, 2012 Author Share Posted September 7, 2012 bump... check out the video with what i'm hearing Link to comment Share on other sites More sharing options...
downtoearth Posted September 16, 2012 Author Share Posted September 16, 2012 bump? watch the video Link to comment Share on other sites More sharing options...
downtoearth Posted January 25, 2013 Author Share Posted January 25, 2013 up from from the dead getting worse Link to comment Share on other sites More sharing options...
downtoearth Posted January 25, 2013 Author Share Posted January 25, 2013 when the brake peddle is depressed it also creaks Link to comment Share on other sites More sharing options...
downtoearth Posted January 26, 2013 Author Share Posted January 26, 2013 the problem is solved i had the idea to check out my pitch mount today the bolt that connected it to the firewall was VERY lose. tightened it up and the problem is GONE :cool::cool: car feels 10 billion times better in general now Link to comment Share on other sites More sharing options...
Bonafide P Posted January 26, 2013 Share Posted January 26, 2013 Niceeeee.. I gotta try that. Link to comment Share on other sites More sharing options...
FJuan Posted January 27, 2013 Share Posted January 27, 2013 downtoearth, this type of sound is also heard from the clutch pedel itself. Underneath the dash were the clutch rod goes through the firewall is a spring. I would get this occasionally and putting some lube around this spring and it's contact points to help reduce the noise. Check to see if this sound is coming from the firewall underneath the dash. I was close to the problem. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
