SpecBlitzed Posted April 20, 2015 Share Posted April 20, 2015 WHEEL: ROTA MODEL: PWR WIDTH: 18-9.5 OFFSET: +38 VEHICLE: STOCK EVERTHING 08 LGT SPEC B TIRES DIMS ID LIKE TO RUN. 265/35 255/35 245/40 HELP ME OUT. I've been playing with the tire calulators but need proof of what will work Last Setup WHEEL: SPARCO MODEL: ASSETO GARA WIDTH:18x8 OFFSET: +40 TIRE DIM: 235/45/18 NITTO MOTIVO NO RUB ISSUES Link to comment Share on other sites More sharing options...
Andy_Mac Posted April 21, 2015 Share Posted April 21, 2015 Surely there is no way that'd work without going with stupid amounts of camber. Even then you'd need atleast 22mm gap from fender to wheel on your current setup and 18mm more on the inside which i'm sure isn't there. Unless you have coilovers? You said stock but they give heaps more room if you want to go real wide. And 255-45 is getting quite alot bigger than the standard setup so speedo will be off by a few miles 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
Drift Motion Posted April 21, 2015 Share Posted April 21, 2015 do you want to put in work? If not, don't get those wheels If so, 225/40/18 for easy fit, 255/35 for meaty fit or choose in between depending on how much work you want to put in and SEARCH n00B Link to comment Share on other sites More sharing options...
GTEASER Posted April 21, 2015 Share Posted April 21, 2015 http://legacygt.com/forums/showthread.php/faq-offsets-sizes-rims-and-tires-gt-xenonk-version-4426.html GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
SpecBlitzed Posted April 22, 2015 Author Share Posted April 22, 2015 Putting in work what you talking about?? Maybe fender roll and pull. I hate the small stretch look of a small side wall. Iam not lowered. It's come down to either a 255/40 or 265/40 Link to comment Share on other sites More sharing options...
GTEASER Posted April 22, 2015 Share Posted April 22, 2015 :lol: GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Drift Motion Posted April 23, 2015 Share Posted April 23, 2015 good choice get some sticky compound too I'll wait for the next post with the wheel/tire combo on Link to comment Share on other sites More sharing options...
SpecBlitzed Posted April 27, 2015 Author Share Posted April 27, 2015 Hmm WILL THEY FIT??? ROTA PWR-RA 18x9.5 +38 255/40/18 http://i1304.photobucket.com/albums/s526/Blake_Westergaard/A3F59BDB-7397-41A7-B893-2D1D367F3B1D_zpsg6bjp3g9.jpg http://i1304.photobucket.com/albums/s526/Blake_Westergaard/3BD09FF4-E7B6-4DE0-83B6-81F6D8016656_zpsbq42drug.jpg http://i1304.photobucket.com/albums/s526/Blake_Westergaard/B2EE7E5C-0799-4BA2-86AE-B5D6E531FF1D_zpsoxjbkcqo.png Link to comment Share on other sites More sharing options...
SpecBlitzed Posted May 5, 2015 Author Share Posted May 5, 2015 IN NEED OF NEGATIVE CAMBER!!! OR SMALLER TIRES??? AND LOWERED??? http://i1304.photobucket.com/albums/s526/Blake_Westergaard/4B1CA7A8-0F75-4C2F-A4F4-D5C85AEDF20A_zps5txjkvdw.jpg http://i1304.photobucket.com/albums/s526/Blake_Westergaard/7DD024F7-BF14-4D27-8A35-DD1D35AAAD4D_zpsy2hphjtc.jpg http://i1304.photobucket.com/albums/s526/Blake_Westergaard/9BA4F8DB-C4C2-4A56-A2A2-789BD4FD6039_zpsienpihro.jpg http://i1304.photobucket.com/albums/s526/Blake_Westergaard/78F3356A-AC02-41F0-BB46-58C73186735A_zps8q1zfe8a.jpg http://i1304.photobucket.com/albums/s526/Blake_Westergaard/17EDB930-7878-4A84-9259-17EB567ADA73_zpsgf8tvi4o.jpg Link to comment Share on other sites More sharing options...
whitetiger Posted May 5, 2015 Share Posted May 5, 2015 whiteline KTA124 or bust. Link to comment Share on other sites More sharing options...
Drift Motion Posted May 6, 2015 Share Posted May 6, 2015 lol Link to comment Share on other sites More sharing options...
SpecBlitzed Posted May 11, 2015 Author Share Posted May 11, 2015 Well. It's gonna take some work 8) but Iam gonna make um fit. What is a quality Coilover?? Iam looking at the BC's. Fronts are EZ max out camber with the camber plates. As for the rear hope the white line bushing are enough. Link to comment Share on other sites More sharing options...
whitetiger Posted May 11, 2015 Share Posted May 11, 2015 BC is not a quality coilover. Link to comment Share on other sites More sharing options...
SpecBlitzed Posted May 11, 2015 Author Share Posted May 11, 2015 Thinking bout going with the Fortune Auto 500 series and custom build them with swift springs. As for the rear camber is the whiteline bushing my only option for camber adjustment. Been researching SPC makes a camber bolt supposedly for the rear on the legacy up to -+ 1.75 degrees. Link to comment Share on other sites More sharing options...
SpecBlitzed Posted May 13, 2015 Author Share Posted May 13, 2015 Ended up poping a front tire on my WRX. Since these tires are too big on the wherl offset. I'll be swapping them over to my WRX and ordering new ones for theses wheels. Either. 245/40 or a 235/40. Link to comment Share on other sites More sharing options...
whitetiger Posted May 13, 2015 Share Posted May 13, 2015 Thinking bout going with the Fortune Auto 500 series and custom build them with swift springs. As for the rear camber is the whiteline bushing my only option for camber adjustment. Been researching SPC makes a camber bolt supposedly for the rear on the legacy up to -+ 1.75 degrees. Fortune auto is garbage too. there is no place for camber bolts on the rear of the 4th gen legacy. instead you need either an adjustable camber arm (whiteline KTA124) or an adjustable camber eccentric bushing (whiteline KCA399). Camber bolts are only for McStrut type suspensions where one of the strut to knuckle bolt hole is slotted for a cam bolt, like in the front of the 4th gen. Link to comment Share on other sites More sharing options...
whitetiger Posted May 13, 2015 Share Posted May 13, 2015 Fortune auto is garbage too. I take this back partially. the 500/510/MSC-1 series is garbage. The Dreadnought Pro 2 way and higher could be good depending on the dyno sheets they give you. If they do a full dyno run for all the adjustments at 3 in/sec and the increments are linear with little crosstalk and the forces are the same across both shocks, on all increments, on the same axle, then they could be good. Link to comment Share on other sites More sharing options...
SpecBlitzed Posted May 17, 2015 Author Share Posted May 17, 2015 Found some cheap 235/40's and real happy I can drive my car now without any serious rub issues. Who has problems with the plastic piece in the rear with the tire popping it off. Either going to trim the plastic till it stops popping off or heat it with a heat gun and bend it around. I rolled my rear fenders enough and I wont be needing the whiteline rear camber bushing. I'll be ordering the Fortune Auto Coilovers probably the 510's soon. Excited to see how it will look with less wheel gap and get some camber in the front to tuck the tops of the wheels in. And of course the better handling!! http://i1304.photobucket.com/albums/s526/Blake_Westergaard/Mobile%20Uploads/image_zpsstqsccil.jpg http://i1304.photobucket.com/albums/s526/Blake_Westergaard/Mobile%20Uploads/image_zps7wdthtyj.jpg Link to comment Share on other sites More sharing options...
Drift Motion Posted May 19, 2015 Share Posted May 19, 2015 I take this back partially. the 500/510/MSC-1 series is garbage. The Dreadnought Pro 2 way and higher could be good depending on the dyno sheets they give you. If they do a full dyno run for all the adjustments at 3 in/sec and the increments are linear with little crosstalk and the forces are the same across both shocks, on all increments, on the same axle, then they could be good. everything to you is garbage Link to comment Share on other sites More sharing options...
SpecBlitzed Posted May 20, 2015 Author Share Posted May 20, 2015 Thought the same thing. Ordered the Fortune 500's with the swifts and radial bearing upgrades. Link to comment Share on other sites More sharing options...
whitetiger Posted May 20, 2015 Share Posted May 20, 2015 everything to you is garbage nope. not garbage list Penske Moton MCS AST Ohlins Dynamic Suspension Sachs Bilstein Koni JRZ there are a couple others im missing but you get the picture. Link to comment Share on other sites More sharing options...
miatabear Posted May 22, 2015 Share Posted May 22, 2015 nope. not garbage list Penske Moton MCS AST Ohlins Dynamic Suspension Sachs Bilstein Koni JRZ there are a couple others im missing but you get the picture. Are you on Ohlins on your miata? Link to comment Share on other sites More sharing options...
whitetiger Posted May 22, 2015 Share Posted May 22, 2015 I'm on MCS 2WNR's Link to comment Share on other sites More sharing options...
