when burping system, take cap off, with car running, let fans kick on. it should bubble. Next give it some gas and it should bubble or might bubble over. fill some more if it gushes out. After it settles, turn off car, put on cap. take the car out and drive it. I did this a year ago and have never had an issue with the OEM therm.
All done new thermostat in. Checked the old one in boiling water and it was working. I think it was stuck and me taking it out fixed it. Tested the new one before it went in just in case. I have heat and no overheating now! We will see how it does on the drive to work Monday. It should fix my problem it was overheating and sucking the top radiator hose closed. Thermostat is the only reason I can think it would do that. No antifreeze in oil or out the exhaust.
