SomethingWittyAsAUsername Posted February 22, 2013 Share Posted February 22, 2013 The hatch handle on my 91 has rusted away to absolutely nothing. Is there any way to open the hatch from the outside or the inside without it? Link to comment Share on other sites More sharing options...
mnstrmech Posted February 22, 2013 Share Posted February 22, 2013 ripping the interior panel off and using the lever........ but you might break the panel... thats about the only way i know of.... Link to comment Share on other sites More sharing options...
snederhiser Posted February 22, 2013 Share Posted February 22, 2013 Hello; Pull the rear license plate and cut a hole smaller than the plate. The latch is just above. Cut a new piece of sheet metal to fill in. Reapply the plate, Steven. Link to comment Share on other sites More sharing options...
Bdubs Posted February 23, 2013 Share Posted February 23, 2013 Spend the $30 to get a new handle and backing plate. Problem solved. Link to comment Share on other sites More sharing options...
Sludgeroo Posted February 23, 2013 Share Posted February 23, 2013 Spend the $30 to get a new handle and backing plate. Problem solved. After he gets it open.. Link to comment Share on other sites More sharing options...
Hemingway Posted February 23, 2013 Share Posted February 23, 2013 ripping the interior panel off and using the lever........ but you might break the panel... thats about the only way i know of.... What he said .. there is a rod inside the lift gate that will open it. The trick will be to remove the plastic retainers on the interior panel and remove the panel. Common issue ... just ordered a new 'license lamp bracket' (the bracket that holds the license lamps and lift gate handle) yesterday ... mine is rusting away and impacting the handle. Link to comment Share on other sites More sharing options...
