Deatschwerks DW300C Fuel Pump w/install kit Install
I installed this on my 2005 Legacy GT.
I decided to grab a DeatschWerks DW300C fuel pump with the install kit since i'll be running E85.
Didnt see a write up on it yet, figured I'd do one.
SOOOO many pictures.
First, go to your favorite parts dealer. I've been nothing but happy with IP&T(and parts show up fast because they're local)...shameless plug
http://images.tapatalk-cdn.com/15/09/17/e56271cbff05315a2e13f5eeead02d2d.jpg
Then open the box after it gets delivered.
Should look like this.
http://images.tapatalk-cdn.com/15/09/17/1c1681df463b4a537e652a73fa49b2f4.jpg
Next, make sure your tank is just about as low as possible for little to no mess.
http://images.tapatalk-cdn.com/15/09/17/10b7407831b4658030d8e8a8566e8c8d.jpg
Pull out the fuel pump fuse, run the car out of gas to relieve the pressure from the lines.
http://images.tapatalk-cdn.com/15/09/17/567eb61a17eb0e82723e31d862eb927c.jpg
Remove the rear seat.
On the passenger side, move the insulation out of the way.
Remove the 4 Phillips head screws from the black access panel.
http://images.tapatalk-cdn.com/15/09/17/e23af035a52930c8a18c350b26f2208f.jpg
Remove the access panel.
If you have driven through the desert like me, it'll look like this.
http://images.tapatalk-cdn.com/15/09/17/d62ecf6b98efca12f862f944975b6134.jpg
If you*have*driven through the desert, you have a bit more time and effort involved. Clean off the fuel pump canister as best you can before going any further.
Unplug the wire harness.
Pull off the 3 hoses.
Next, remove the 8mm nuts(8 of them) holding the canister/pump in the tank.
http://images.tapatalk-cdn.com/15/09/17/76f25f872695323b3b10a444bc72f7a4.jpg
Pull out the metal retaining ring.
http://images.tapatalk-cdn.com/15/09/17/aa774516f24ab6e71eecb24e8cf60e3b.jpg
Pull the whole canister out of the tank. I actually managed to keep all of the gas in the tank and the pump housing. Held it over the tank for a minute, then took it out of the car when it stopped dripping.
http://images.tapatalk-cdn.com/15/09/17/6ec3638fd3bb840d2b9c8f2771db49f2.jpg
I covered the tank so no debris wouldn't fall in while swapping the pumps.
Then, you set your fuel pump canister on your "bench"(a truck tailgate in my case". I used cardboard to help soak up left over gas.
Next, knock it over so that the majority of gas sitting in it goes everywhere. Finish dumping out the rest in a bucket.
http://images.tapatalk-cdn.com/15/09/17/91251c02b1814174e1279be9707f3a8c.jpg
After all of that mess is over, Remove these two wire plugs.
http://images.tapatalk-cdn.com/15/09/17/bdb8a4dd784d843eeec4901ab7325e86.jpg
Next, pop off these 4 clips that hold the cup to the bottom of the pump assembly, and slide it off.
http://images.tapatalk-cdn.com/15/09/17/6d2bd6b25f44b3f4ba585346340ffdc6.jpg
Look at all the crap sitting in the bottom. and how much is stuck to the sock. Clean it out.
http://images.tapatalk-cdn.com/15/09/17/3c1ebb77471247ba26298feef65f3309.jpg
http://images.tapatalk-cdn.com/15/09/17/9df1c4e8665ca806b95bda9242df5871.jpg
Pull the hoses off the bottom near the sock filter.
http://images.tapatalk-cdn.com/15/09/17/0aa8de71569d7612ec21ecd3fafd6785.jpg
http://images.tapatalk-cdn.com/15/09/17/a1ad508b9644132451b0b97eaa980ff4.jpg
Now, compress the springs and remove the C-clip.
http://images.tapatalk-cdn.com/15/09/17/3974f6b8103126fb21ed62b6e72d6010.jpg
http://images.tapatalk-cdn.com/15/09/17/ae200474a18a2e57b72602f13e44a450.jpg
Separate the top and bottom.
Unplug the wire harness from the fuel pump.
http://images.tapatalk-cdn.com/15/09/17/f96d121bd52c4f8ab485a3d18d331740.jpg
Be patient and get crafty with two flat head screwdrivers to free the pump from the housings angry clutches...unclip one side, and then the other.
http://images.tapatalk-cdn.com/15/09/17/3cf68cd823adf0ca566fb1f08509f47d.jpg
"Build" Thread <--Link
(OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW)
Forever Slow
[sIGPIC][/sIGPIC]
Slide the pump out.
http://images.tapatalk-cdn.com/15/09/17/47b05124d4cc9a865cecf35a612d48f7.jpg
Put pumps next to each other to see how similar they are for no real reason.
http://images.tapatalk-cdn.com/15/09/17/039086a6776562432a6f4294afbf5855.jpg
Move the o-ring "pusher" from the old pump to the new pump, lube and install the new o-rings on the pump outlet.
http://images.tapatalk-cdn.com/15/09/17/d5d90ca4fbef99acb0a34cdc6469fde3.jpg
Slide the pump back into its plastic coffin home, make sure both clips lock.
Install the filter sock, lock it in place with the supplied lock washer.
http://images.tapatalk-cdn.com/15/09/17/09b4f881cec90bba7b131e2416c6918b.jpg
Plug in the wires to the pump.
Put the top and bottom housing back together, and reinstall the C-clip to keep it together.
Plug the hoses back into the bottom of the canister.(I lubed all the o-rings, green one stayed in the housing, so i pulled that out first)
Plug the pump wires back into the top of the housing.
Slide the bottom cup back on the assembly, making sure all 4 clips lock it in place.
Plug in the fuel level wires.
Slide the assembly into the gasket on the tank.
Take your finished assembly and put it back into the tank.
Put the black retaining ring on the assembly and make sure the gasket, pump canister, and retaining ring are in the correct orientation.
Put the 8mm(8 of them) nuts back on compressing the springs on the assembly. Snug them down goodentight.
http://images.tapatalk-cdn.com/15/09/17/df3c03e881b7bf2c27d71faaee1e4126.jpg
Reconnect the fuel lines and wiring harness.
Put the Fuel pump fuse back in. Cycle the key a few times, make sure the pump fills the canister up(I was able to hear it), and pressure back in the lines. Checking for potential leaks as pressure builds. Start the engine to make sure all is well.
After being satisfied with the lack of leaks, and adequate fuel delivery, reinstall the black access cover and 4 phillips head screws that keep it in place.
Replace the insulation, and the seat bottom and go make the boosts!
I had like 70 pics, but edited it down to 25, and it still needs two posts...just being through.
Forever Slow
[sIGPIC][/sIGPIC]
The DW alone let the pump slide up and down a bit more than I'd like. Stock pump didn't move at all.
I saw people were doubling the o-rings on the walbro pumps, so I figure I'd git it a go.
I can always get the bigger light and seal and swap it in later. As long as you have all the tools with you on everything, you could probably do this in like a half hour
Forever Slow
[sIGPIC][/sIGPIC]
Just did some research and it looks like DW does recommend using both o-rings on the pump install.
Install Instructions
http://www.deatschwerks.com/images/stories/products/fuelpump/08%20Subaru%20DW65c%20Fuel%20Pump%20Installation%20Guide.pdf
Post on NASIOC
http://forums.nasioc.com/forums/showthread.php?t=2592904
Woo hoo! I did something right haha...half right. I reused one stock o-ring on the pump.
The DW o-rings are a bit smaller O.D.
I swear, I did sort of skim the directions, but missed that part.
Thanks for that link, its got all the info there!
Like I said, it's pretty straightforward, it's just one step before the other. But that still would have been nice to have. There really aren't any directions that come with it.
Forever Slow
[sIGPIC][/sIGPIC]
  • 5 months later...
  • 1 month later...
This guide worked great for installing a DW65c. Better than DeatschWerks' own pdf.
I also replaced the fuel filter. It's that entire assembly in white:
The only reason to remove the OEM fuel pump, if you are replacing the filter, is to harvest the o-ring spacer. (will update if I can find it's part number, as it would save some time and frustration popping out the pump)
Thank you!
Glad it worked for you.
Forever Slow
[sIGPIC][/sIGPIC]
  • 2 weeks later...
Just used this to install a DW65c as well per RooTBeeR's guide. So much clearer than the DW one!
A tip is any of you guys run into pinched orings like I did and the dealer is closed: You CAN revive them with just a cup of water and a microwave. Put oring in cup, place in microwave, heat on high for ~4 minutes. Pull it out and it'll be back to the original shape.
The green one for that black plug with no opening go into the filter was pinched pretty bad. Just put everything back together and it seems to work. Car isn't completely drivable so I can tell if thing are 100% sealed yet.
  • 2 weeks later...
Thanks for this write up!
At the risk of sounding like an idiot... Is there a need to re-tune, change fuel pressure, or make any other changes after the install on an otherwise stock LGT? I will be re-tuning once I install some other mods, but was hoping to install the fuel pump on my own first.
I may replace the fuel pressure regulator as well (when I install the fuel pump or I may have the shop who tunes do it)... any idea how this would impact fuel delivery? Am I going to need to install a fuel pressure gauge to adjust the FPR to match stock pressure after the fuel pump and / or FPR?
Thanks for the help guys!
  • 1 month later...
  • 9 months later...
After replacing my ancient fuel pump today with deatschwerks 300, my tuner indeed brought out the laptop and made some changes to the tune. It solved like eighteen different issues in fell swoop (ok, only four maybe). Very happy!!!
Recurring misfire 0304 was only due to last cylinder being starved for fuel. New pump = engine running smooth as can be
More torque
Stabilized idle
Burning less oil / engine throwing off way less heat
Even the AC seems to work a little better!!!
:spin:
  • 2 months later...
  • 1 year later...
Thank you for putting this tegether. Particularly helpful for those us planning to run E85.
I took the liberty of converting this to a PDF. I like to keep these in my How-to binder for easy/quick reference.
Please advise if I've missed anything.
Rootbeer’s DeatschWerks DW300C Fuel Pump Install Walk-through.pdf
