bballdude1414 Posted September 9, 2013 Share Posted September 9, 2013 would 18in rims fit my 98 legacy with stock suspension and non rolled fenders? found a great price on a set, they are 225 40 R18 Link to comment Share on other sites More sharing options...
Scruffy Posted September 9, 2013 Share Posted September 9, 2013 I would imagine not, since your car runs 205/55/16. The 205 is basically the tire width measured in millimeters. Which means that the width of the tire is 205 millimeters (from inner sidewall to the outer sidewall). Then the 55 is the Aspect Ratio. The aspect ratio is a number that indicates the height of the sidewall (from the edge of the inner rim to the tread) in relation to the section width. In our example we have an aspect ratio of 55, this means that the height of the sidewall is 55% of our section width of 205mm. The higher the aspect ratio - the higher the sidewall, the lower the aspect ratio - the lower the sidewall. Link to comment Share on other sites More sharing options...
Scruffy Posted September 9, 2013 Share Posted September 9, 2013 Also, Welcome fellow Vermonteer. Link to comment Share on other sites More sharing options...
Zues Marine Posted September 9, 2013 Share Posted September 9, 2013 you will need spacers to keep the tire off the strut Link to comment Share on other sites More sharing options...
lockmedic Posted September 9, 2013 Share Posted September 9, 2013 I can say that 2000+ 16" rims running 225/60-16 fit without issue. . . so 225/40-18 probably should provided the wheels are the correct offset. 215's would probably be better tho. Bolt them up and see. Link to comment Share on other sites More sharing options...
Zues Marine Posted September 9, 2013 Share Posted September 9, 2013 these aren't 2000+ cars, that info is irrelevant Link to comment Share on other sites More sharing options...
lockmedic Posted September 9, 2013 Share Posted September 9, 2013 Sorry if I wasn't clear: I'm saying I've put OEM 2000+ 16" rims running 225/60-16's on first gen (96-99) Outbacks without issue. I am talking about Outbacks, which run slightly taller tires than Legacy. As 225/60-16's are actually about 1.5" taller overall than 225/40-18's, I know they'd fit an Outback. Legacy, dunno. If they're local, drive over, bolt one on each end of the car and see if they clear. This is handy for answering questions like this: http://www.miata.net/garage/tirecalc.html 205/55-16 to 225/40-18 is only 0.2" taller, 0.6" longer circumference. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted September 9, 2013 Share Posted September 9, 2013 I guess it depends on the offset of the rims too. Mine are 215/55-17 and they fit, but there really isn't much space at all between the spring perch and the tire. Link to comment Share on other sites More sharing options...
Zues Marine Posted September 9, 2013 Share Posted September 9, 2013 it really is all about the offset^ with maybe 5-10mm spacers you'll get the tire off the perch but im sure if theyre OEM subaru wheels youll hit it I'm running 235/45/17 and im about .0000000000000000005" off the perch with the offset of 4thgen Legacy wheels Link to comment Share on other sites More sharing options...
bballdude1414 Posted September 10, 2013 Author Share Posted September 10, 2013 thinking ima just keep looking for 17s and not take a risk, thanks guys and keep me posted if anyone is selling some 17s Link to comment Share on other sites More sharing options...
