levihamernik Posted January 11, 2013 Share Posted January 11, 2013 So today I got out of class and walked down to my car. I got in started her up and got about ten yards down the road before it started making a god-awful sound. I pulled over and shut it off. let it sit for a bit then tried moving it again. the second time it made it not even 5 yards before dying meanwhile the car was shaking violently. The only way I can describe the sound is a hacksaw going through metal, while a washing machine is running violently. Currently sitting at the mechanic waiting to be checked out... Any ideas what it might be? I feel this may be the end of my Subbie Link to comment Share on other sites More sharing options...
WESTcoast Posted January 11, 2013 Share Posted January 11, 2013 sounds like maybe your threw a rod or two. But its sounds like something big Link to comment Share on other sites More sharing options...
Gex Posted January 11, 2013 Share Posted January 11, 2013 Spun Bearing Link to comment Share on other sites More sharing options...
Stang70Fastback Posted January 11, 2013 Share Posted January 11, 2013 Yeah, that does sound like a rather serious issue... sorry man Link to comment Share on other sites More sharing options...
SpecBamf41 Posted January 11, 2013 Share Posted January 11, 2013 spun idler bearing. sezed BNR18g on 93oct Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 11, 2013 Share Posted January 11, 2013 Sorry to hear about your engine. Your body is clean though. If it was mine I would do a motor swap or rebuild if possible. Sucks super bad. Link to comment Share on other sites More sharing options...
levihamernik Posted January 11, 2013 Author Share Posted January 11, 2013 Yeah, waiting to hear back from mechanic either tomorrow or monday. If I wasn't a high school student I would consider doing a swap but its just not realistic. The strange thing is that I drove it around town all day without an issue, and nothing happened while driving. Only when I started it up did things really go downhill. Im thinking if its to far gone to do anything I will take what I can for the scrap and try to pick up a newer Forester. Link to comment Share on other sites More sharing options...
spooln30 Posted January 11, 2013 Share Posted January 11, 2013 Did you piss anybody off cuz I've heard of guys pulling people's oil drain plugs while their cars were parked and we all know what happens to an engine with no oil. Link to comment Share on other sites More sharing options...
johnegg Posted January 11, 2013 Share Posted January 11, 2013 assuming you are talking about your 98 GT w/ 2.5L engine, you are looking at a timing belt job at the least or most likely a valve job with new head gaskets or worst case a junk engine. if the timing belt idler died, very very very common, chances are a new belt parts and a few new valves will put it back on the road. but if the t-belt and idlers are intact then you probably have rod / bearing problems which generally mean a different engine is the way to go. good luck. Link to comment Share on other sites More sharing options...
levihamernik Posted January 11, 2013 Author Share Posted January 11, 2013 Highly unlikely that I pissed somebody off to that point. I go to a fairly preppy school where people are a little less than mechanically inclined, and most drive new BMWs, Audis, etc. that mommy and daddy bought for them. I doubt anyone that I may have pissed off would have the knowledge to pull the drain plug. If the timing belt and Idlers were gone wouldn't the car not even turn over and move at all? Just a thought. Link to comment Share on other sites More sharing options...
johnegg Posted January 11, 2013 Share Posted January 11, 2013 if the belt is still in one piece and in place it could have jumped time when the toothed idler seized. and then when the ball bearings fell out of the idler and it unfroze, it COULD still be turning the cams. but this is all speculation. wait for the report and see what they say. if it is anything more than just a timing belt, and i'm pretty you are, the shop costs are likely going to be WAY more than the value of the car. BUT that is not the comparison to make. you have to compare the repair cost to ''what can i buy for that much money? and how reliable will it be?'' the cheapest way out is probably a 2.2L engine swap. you can buy one for $500 of less and have it installed for $500 to $750. but again, this is premature. you need the shop report. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted January 11, 2013 Share Posted January 11, 2013 EJ22 for $450 @ parts yard, drop in (easier than you think), & just keep going until the wheels fall off. The same thing happened to my 2.5 about a year & a half ago. Link to comment Share on other sites More sharing options...
levihamernik Posted January 11, 2013 Author Share Posted January 11, 2013 Bearing broke timing belt slipped. 230 to put on used parts and see if that's the only problem. If it is it will be an additional 600 for new bearing and belt. If valves are damaged and head gaskets hit them, then it'll be 2-3k... He's gonna do the used parts on this after noon and give an update. If its just belt and bearings ill do it, but if its the valves I'm gonna scrap it or sell it to someone looking for a clean body, and find something new. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted January 11, 2013 Share Posted January 11, 2013 Bearing broke timing belt slipped. 230 to put on used parts and see if that's the only problem. If it is it will be an additional 600 for new bearing and belt. If valves are damaged and head gaskets hit them, then it'll be 2-3k... He's gonna do the used parts on this after noon and give an update. If its just belt and bearings ill do it, but if its the valves I'm gonna scrap it or sell it to someone looking for a clean body, and find something new. It will not be 2-3K if you buy the parts needed, then have him do it. Our engines are not that expensive to fix if you can buy the parts yourself. Plus you can always buy DOHC cylinder heads from other GTs/Outbacks that are ready to go. Just saying that there are cost effective ways to get your car going. Link to comment Share on other sites More sharing options...
levihamernik Posted January 11, 2013 Author Share Posted January 11, 2013 Valves are fine. 1200 for new pulley, bearing, timing belt, and water pump. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted January 11, 2013 Share Posted January 11, 2013 Luuccckkkyyyyyyyy... Link to comment Share on other sites More sharing options...
Kiyo1990 Posted January 11, 2013 Share Posted January 11, 2013 Damn, you got out lucky there. I think that is a little high, but as long as she is back hell yeah Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted January 12, 2013 Share Posted January 12, 2013 Valves are fine. 1200 for new pulley, bearing, timing belt, and water pump. Lucky! Those heads should have been toast! Glad you got everything sorted out though. Our cars last a long while but when they break, boy do they make it idramatic! Link to comment Share on other sites More sharing options...
jp71ss Posted January 12, 2013 Share Posted January 12, 2013 Wow, very lucky but I agree that seems a lot high on the price. Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 12, 2013 Share Posted January 12, 2013 You list the bearing as a part that needs to be replaced. What does the mechanic mean by bearing? Which part specifically? Do you mean idler? Link to comment Share on other sites More sharing options...
levihamernik Posted January 15, 2013 Author Share Posted January 15, 2013 picked her up from the mechanic today. Saw 3 identical legacys. All black late 2nd gen gt wagons. Over 20 2nd and 3rd gen legacys and outbacks along with probably 30 foresters. Anyways picked her up and she is running better then ever. Glad it wasn't to major. Link to comment Share on other sites More sharing options...
levihamernik Posted January 15, 2013 Author Share Posted January 15, 2013 Heres some pics from on my way home. Link to comment Share on other sites More sharing options...
