yonith Posted August 17, 2015 Share Posted August 17, 2015 So frustrated right now. I got my Koni struts, tein h springs, and Monroe mounting kits in the mail and brought it to a local shop for install today. The guy is saying I got "all the wrong parts" and should have gotten the quick strut kit instead. He was gonna do the install for 575 with an alignment included. The other place I went to wanted 800. Can anyone recommend a shop to do this install? I'm in South Jersey, Sewell specifically, like 20 minutes southeast of philly. What is a fair price for the install? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 17, 2015 Share Posted August 17, 2015 Its a little drive but Mike's guy's at www.AZPinstalls.com might be able to recommend someone or you can ask them how much. Tell Rey I sent you. I've been buying stuff from them for years. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gto7419 Posted August 17, 2015 Share Posted August 17, 2015 Fill out your profile. 800 is crazy. 500 is more realistic Link to comment Share on other sites More sharing options...
GEE-OTTO Posted August 17, 2015 Share Posted August 17, 2015 You do realize the Konis require cutting up the stock front struts so they are charging you for that service im sure. I steer clear of monroe parts all KYB, all OEM (tophats and shocks) Link to comment Share on other sites More sharing options...
yonith Posted August 17, 2015 Author Share Posted August 17, 2015 You do realize the Konis require cutting up the stock front struts so they are charging you for that service im sure. I steer clear of monroe parts all KYB, all OEM (tophats and shocks) Yes I do realize that. I found another guy who can do it and charges by the hour ($100). He was saying at least 4 hours. I'm guessing it will take 6 hours with the cutting. Link to comment Share on other sites More sharing options...
apexi Posted August 18, 2015 Share Posted August 18, 2015 I don't think there's a quick strut for our cars, I briefly looked last year when it came time to replace my struts. There are full coilovers, but those are big bucks. Link to comment Share on other sites More sharing options...
Dujo Posted August 18, 2015 Share Posted August 18, 2015 Cut a strut is the Koni way. They make a few prebuilt kits, but they save a ton on R&D and fab costs as well as avoiding a lot of stale inventory by making their line of shocks fit into a huge variety of cars by reusing strut housings. There is no Koni kit already built for the Legacy. Koni is the best option short of coilovers. And you need to get pretty damn expensive coilovers to beat the Koni performance. Get the aftermarket spring of your choice and use OEM for the rest. Top hats and strut bearings should probably be new. Dust shield and bump stop can be reused. By the way, if you're feeling ambitious. You can do this job yourself. All you really need is a pipe cutter and spring compressors, which you can rent from Auto parts stores for cheap. Read here: http://legacygt.com/forums/showthread.php/koni-shock-strut-epic-engineering-spring-install-145744.html Enjoy! Welcome to LGT.com. Link to comment Share on other sites More sharing options...
Rester5350 Posted August 18, 2015 Share Posted August 18, 2015 I imagine you talked to the guys at Fast? If not try them. I did the swap on my car and have the right pipe cutter, Only other thing needed is a spring compressor. You can get them from autozone for free rental. If you want to borrow my pipe utter lmk. It a pretty straight up job. Link to comment Share on other sites More sharing options...
yonith Posted August 18, 2015 Author Share Posted August 18, 2015 I got a tip that a Meineke near me is good and went there. Got the job done with an alignment for $545. I can't tell u how happy I am with the Koni + tein h tech combo. Keep in mind my old shocks were completely beat, but I can tell you the ride is so much better. Still feel bumps of course but it's much more dampened. The biggest difference is going around jughandles. I swear I'm not used to turning the wheel so much bc the car used to have so much roll. A++ Link to comment Share on other sites More sharing options...
GEE-OTTO Posted August 19, 2015 Share Posted August 19, 2015 Nice, I run that same combo and I love it. I also installed mine myself took around 3.5 ours total. Glad you went with a proven setup over cheap C/Os Link to comment Share on other sites More sharing options...
quick4dr Posted August 20, 2015 Share Posted August 20, 2015 for future note, AZP is my go to shop. if its work i cant handle on my own, Mike and Ray are my go to shop. Honest, affordable, genuine enthusiast care! when in doubt azp it out! Link to comment Share on other sites More sharing options...
