1-3-2-4 Posted June 27, 2015 Share Posted June 27, 2015 Anything decent and bright enough? I don't have the time to do the custom work I did before it was time consuming but I was just seeing what's out. Link to comment Share on other sites More sharing options...
Silinc3r Posted June 29, 2015 Share Posted June 29, 2015 Look up "switchbacks" from r-rev. That is what most of us have. Silinc3r's 05 SWP GT/Spec B Link to comment Share on other sites More sharing options...
oldskoolbiker Posted June 30, 2015 Share Posted June 30, 2015 I got these: http://www.theretrofitsource.com/led-lighting/morimoto-xb-led-3157-bulbs.html#.VZLoKflViko and this: http://www3.telus.net/s_mcphee/orderTAP.html Link to comment Share on other sites More sharing options...
OXD Posted June 30, 2015 Share Posted June 30, 2015 I tried switchbacks paired with the Tap-Turn module but they never worked right (only the amber turned on) and the signal brightness its self was underwhelming to me in the daylight. Even under overcast skies signal visibility was questionable. I went back to just the standard corners. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 30, 2015 Author Share Posted June 30, 2015 That's what I had a feeling my custom way was the only thing that was decent in full brightness in the day time but it was expensive and time consuming. Link to comment Share on other sites More sharing options...
Shogun506 Posted July 2, 2015 Share Posted July 2, 2015 I have LED switchbacks from eBay. I don't want to upstage the vendors on here but I got them for a better price and they are very good quality I can send you the link if you like. Check out my turn signals here: Definitely bright enough during the day and extremely bright at night. Check out my lighting video below to see them blinking normally and the brightness at night after installing a $10 relay from Diode Dynamics. Link to comment Share on other sites More sharing options...
Kevin622 Posted July 3, 2015 Share Posted July 3, 2015 I have LED switchbacks from eBay. I don't want to upstage the vendors on here but I got them for a better price and they are very good quality I can send you the link if you like. Check out my turn signals here: Definitely bright enough during the day and extremely bright at night. Check out my lighting video below to see them blinking normally and the brightness at night after installing a $10 relay from Diode Dynamics. If you can send me the link that would be great I will be needing these once I finish my headlights . Btw yours look great! Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 3, 2015 Author Share Posted July 3, 2015 I will buy those then I replace both my front headlights, for whatever reason the '05 they cloud from the inside out.. and I hate cloudy headlights so I will be buying replacements and putting in some RX330 HID projectors. Link to comment Share on other sites More sharing options...
quick4dr Posted July 3, 2015 Share Posted July 3, 2015 If your housing clouded out from the inside them too much moisture has been present inside them, usualy inner lens brake down doesnt happen unless the housing was breached. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 3, 2015 Author Share Posted July 3, 2015 No its haze not moisture Link to comment Share on other sites More sharing options...
Kevin622 Posted July 4, 2015 Share Posted July 4, 2015 It is the inside of the lense.. I just pulled a pair apart and had to buff to remove whatever they coat the inside of the lense with. I will be having my father professionally clear them inside and out Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 4, 2015 Author Share Posted July 4, 2015 I'm just going to buy a new pair so I don't have to deal with it for a few years Link to comment Share on other sites More sharing options...
Kevin622 Posted July 4, 2015 Share Posted July 4, 2015 ill let you know how they come out. Link to comment Share on other sites More sharing options...
jjgear Posted September 8, 2015 Share Posted September 8, 2015 Shogun Can you send me a link Link to comment Share on other sites More sharing options...
gonzoman10 Posted September 19, 2015 Share Posted September 19, 2015 Take a look at this thread. He has a really clean and great looking LED set for his headlights and if I remember right they work as turn signals as well. http://legacygt.com/forums/showthread.php/led-headlight-strips-228627.html Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 20, 2015 Author Share Posted September 20, 2015 Yeah those look pretty good Link to comment Share on other sites More sharing options...
Dannyboy402 Posted September 24, 2015 Share Posted September 24, 2015 I have switchbacks and turn-tap and mine work just fine and are plenty bright. I can't remember what brand the switchbacks are... Link to comment Share on other sites More sharing options...
Lindsay Posted October 9, 2015 Share Posted October 9, 2015 Shogun...... Link please. Link to comment Share on other sites More sharing options...
Kalien32 Posted November 14, 2015 Share Posted November 14, 2015 I got the switchbacks from diodedynamics. They are very bright. And i, personally, think they are far more aesthetically pleasing bulbs, when not lit... The quality it's unmatched by anything else I've used... and I tried 2 other brands. Link to comment Share on other sites More sharing options...
