jbowler Posted April 24, 2013 Share Posted April 24, 2013 im working on my friends 2002 legacy l wagon today half of the coil pack stopped producing spark. I tried another coil pack and the problem persists. im thinking that it is an issue with ecu or the wiring to the coil pack. does anyone have a wire diagram for this car either for ecu or ignition system? or maybe a different solution to my problem? its cyl 3 and 4 on the coil pack that does not work. also this is my first post here on the forums ..thanks for having me! Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 24, 2013 Share Posted April 24, 2013 Try the BE/BH section (2000-2004) Legacy area those guy/gals probably have a wiring diagram for that year range that help you out. Also have you check the wiring loom btwn the coil pack and the firewall for any rubbed/melted wires? Ive seen the main harness get chew in half by careless placement during some turbo work. Link to comment Share on other sites More sharing options...
jbowler Posted April 25, 2013 Author Share Posted April 25, 2013 thanks for the reply. the issue was inside the bulkhead conector the pins where corroded. oddly enough that was the only pin that was corroded... Link to comment Share on other sites More sharing options...
