Clutch Issue
So I finally get my car running again and installed a new clutch. The only problem is that when taking off from a dead stop in either reverse or first gear, the drivetrain feels like it's about to explode and the car shakes horribly. Sometimes it comes from the rear, sometimes from the front. It doesn't matter how clutchy i am with it, it still does it. But if the car is moving everything operates like it should. I had the flywheel turned, installed the clutch properly, and tightened everything down. I know i need a new master cylinder, but that wouldn't cause anything like this. Any ideas?
