funny noise turned out terribly
Well last week my car was running really lean due to my ebcs so i replaced it it still wasent running good. Now my motor is blown and my turbo. So i am now building my engine fully forged internals, and adding a nice amr cxr500 turbo on it. Ill post a build sheet up later. Im hoping for a safe 400whp on pump.
  • Replies 381
  • Created
  • Last Reply
here is my current list of parts and mods to the car and this list will be growing:
hawk hps+ pads on front and rear
DBA 4000 slotted front and rear rotors
Magnaflow CBE
invidia catless dp
Greedy Up pipe
DW 850cc injectors
DW 300lph fuel pump
rallitek skid plate
Killer B oil pick up
CP pistons 100mm oversized 9:1 compression custom coated
Acl race bearings
tein s tech spring
AVO front mount
STi intake manifold
GS power division 272 cams
Gs power division billet springs and retainers
Ported b25 heads
AMR CXR 550 turbo
Open source tune
ARP head bolts
Custom tgv deletes
Grimmspeed ecbs
STi nitrite treated crank
2011 STi connecting rods
Perrin turbo inlet
perrin cold air intake
NGK one step colder spark plugs
GSC springs and retainer kit
Gates kevlar timing belt
GFB bov vent to atmosphere
ACT 6 puck
ACT streetlight fly wheel
Kartboy sts
polished and ported stock heads
bored cylinder walls
wrx pedal set
avo grill
STi boost gauge
New avcs system
Gfb manual boost controller
Group N motor mounts
and a lot of headaches
the tear down
http://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs065.snc6/167555_10150093959428305_113984963304_6097696_6091692_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs765.ash1/165661_10150094105888305_113984963304_6099454_7390545_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs800.ash1/168999_10150094105918305_113984963304_6099455_7987200_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs041.snc6/167164_10150094105953305_113984963304_6099457_1291186_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs740.ash1/163207_10150094106003305_113984963304_6099459_3008762_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs1391.snc4/164338_10150094361508305_113984963304_6102725_5891700_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs264.snc6/179213_10150094361548305_113984963304_6102726_1044212_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs043.snc6/167308_10150094361593305_113984963304_6102728_2459454_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs273.snc6/180169_10150094361638305_113984963304_6102729_6132584_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs077.snc6/168724_10150094361673305_113984963304_6102731_6342519_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs040.snc6/166999_10150094361693305_113984963304_6102732_8329578_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs062.snc6/167241_10150094361738305_113984963304_6102734_3059596_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs1362.snc4/163435_10150094361773305_113984963304_6102736_5715302_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs048.snc6/167880_10150094361808305_113984963304_6102737_2154564_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs080.snc6/169089_10150094361853305_113984963304_6102739_5370101_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs252.snc6/179996_10150094361958305_113984963304_6102743_1839154_n.jpg
the parts
http://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs248.snc6/179675_1545228436264_1401600109_31277015_594704_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs254.snc4/40024_1357409260902_1401600109_30888130_3057668_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs137.ash2/40183_1375214306017_1401600109_30937320_7085387_n.jpg
So, what was the failure? I'm recovering from LASIK (yesterday) and can't stare closely at the pics, but I'm guessing ring lands? What was the failure of boost control? Too much boost? If so, I'd say a boost gauge should be on your list as well. IMO anytime you start modifying an engine, a boost gauge should be on the list, since you never know when you'll start having issues with boost creep, vacuum lines blowing off, boost controller failures, etc.
Good luck on the build. I'm actually kind of keeping my eyes on this for the sti engine that will be going in my 98 LGT.
Any indicators - noise, performance issues, etc.?
BTW - If you haven't planned it already, don't forget your phenolic spacers, since you're replacing the resin intake with a metal one. Need to minimize the heat sink capacity of the STI intake.
Red Manifold = STi manifold.
Doesn't it look sexier? :p
And it's a bit different so the flow may be better. At least that's something to hope for.
Actually, the plastic intake manifolds flow more and better. There are no casting marks on the inside to restrict flow. Topspeed seems to love them.
Good luck with your build and remember to take your time.
i went with the sti intake manifold because im gonna port it out, and i honestly like the red. I do know that the stock plastic ones flow fine and dont retain heat as much as the red metal ones do, but i want a clean looking engine bay and something to go along with my crinkle red turbo and my red inlet hose.
So how easy are these engines to work on? I may need to be rebuilding my bro's at some point/ swapping a built shortblock with his current heads.
Would probably end up doing a similar setup with the cxr500 and internals.
Working under the hood of a Subaru is very simple because there is a lot of room. Disassembly of the engine is just like any other, and splitting the case is no big deal. IIRC there are plates in the block that allow you to access the connecting rod bolts so you can separate the case without pulling pistons out of the bore.
Thanks! I saw a video of disassembly and it looks pretty easy.
Howd did the ebcs cause the car to run lean? Untuned? Was unmetered air entering the engine? If overboosting was overboost fuel cut disabled?
My '05 LGT
My '07 Supercharged Shelby
Good question - there has to something else going on. Too much boost, so too much airflow, and then not enough fuel flow capacity, maybe?
