Brian55 Posted September 4, 2014 Share Posted September 4, 2014 Does anyone know how I could identify whether a down pipe is for AT or MT? I've had one sitting around so long now that I can't remember which car it fits. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 10, 2014 Share Posted September 10, 2014 Later today if I remember I can measure the one I have in the shed. Its for a manual. The support bracket is the only difference. From the passenger side of the DP, I measured from the "front of the car side of the flange at the mid pipe" to the front of the car side of the support bracket, 20". It's a pretty straight shot when standing above it looking down. I put the turbo end on my work bench so it sits like its in the car. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Brian55 Posted September 11, 2014 Author Share Posted September 11, 2014 Later today if I remember I can measure the one I have in the shed. Its for a manual. The support bracket is the only difference. From the passenger side of the DP, I measured from the "front of the car side of the flange at the mid pipe" to the front of the car side of the support bracket, 20". It's a pretty straight shot when standing above it looking down. I put the turbo end on my work bench so it sits like its in the car. Thanks for taking the time to check it out. I just went out and measured the pipe the same way and came up with 20.25". Just to clarify, is this the measurement for an a/t or m/t? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 14, 2014 Share Posted September 14, 2014 MT, in fact I didn't even bolt the hanger to the DP. I had a hard time getting the bolt to thread into the nut on the bracket. My wagon has not used that bracket. Its my DD over 20,000 miles a year, no issues. This DP went into my Spec B. Both are Invidia DP's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Brian55 Posted September 14, 2014 Author Share Posted September 14, 2014 If the bracket isn't really necessary would I be able to use the pipe with either trans. or are there clearance issues? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 15, 2014 Share Posted September 15, 2014 I think you can put a mt on a 5eat but not the other way around. or is it the other way, the 5eat is bigger. Ask "m sprank" he would know. Do any of the vendors have pictures of each... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmpequeno Posted September 16, 2014 Share Posted September 16, 2014 Interested on this too. Trying to find a cheap DP, found one but it's for MT. Link to comment Share on other sites More sharing options...
Brian55 Posted September 16, 2014 Author Share Posted September 16, 2014 Interested on this too. Trying to find a cheap DP, found one but it's for MT. That's where I'm at now as well. Now that we've established that the pipe I have is for m/t. I'm curious whether or not I can make it work on a 5eat that we're considering buying for the wife. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 16, 2014 Share Posted September 16, 2014 I think "m sprank" knows the answer. PM him. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
m sprank Posted September 17, 2014 Share Posted September 17, 2014 I have previously posted pix of MT and 5EAT OEM and aftermarket down pipes side by side. A 5EAT pipe will "fit" a MT, but not the other way around. The hanger is in a different location and the pipes are bent slightly differently for clearance around the trans. I do not recommend using the incorrect pipe as it puts undue stress on the hotside of the turbo (weight of exhaust hanging from turbo). Link to comment Share on other sites More sharing options...
Mike07LGT Posted September 19, 2014 Share Posted September 19, 2014 Im looking to purchase a downpipe if anyone wants to part with theirs... I have an 07 MT. Thanks!! 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
Brian55 Posted September 20, 2014 Author Share Posted September 20, 2014 Im looking to purchase a downpipe if anyone wants to part with theirs... I have an 07 MT. Thanks!! PM sent. Link to comment Share on other sites More sharing options...
Brian55 Posted September 22, 2014 Author Share Posted September 22, 2014 I have a brand new Perrin catless for MT, if anyone is interested. Local pickup only, northern IL. I'd be willing to meet someone half way. Send me a PM if you're interested. Link to comment Share on other sites More sharing options...
m sprank Posted September 23, 2014 Share Posted September 23, 2014 The classifieds are for selling. Link to comment Share on other sites More sharing options...
