05wagongt Posted December 7, 2012 Share Posted December 7, 2012 as my car is waiting for new engine to be installed, my garage said they would install the catless uppipe and let me keep ,y warranty after i showed them the problems the catted one causes.... so with that said, perrin or cobb? and will stock gaskets work or do i need a different set? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted December 7, 2012 Moderators Share Posted December 7, 2012 Neither. Just find a stock STI up pipe and use that. Stock gaskets are fine, just use new ones. I used a couple of GTSpec gaskets as well and they worked fine. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
05wagongt Posted December 7, 2012 Author Share Posted December 7, 2012 ok, but if i cant find a stock sti uppipe? i check cl everyday, i havent found one yet... Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted December 7, 2012 Moderators Share Posted December 7, 2012 I had really good luck posting a "WTB" thread on nasioc. If not, I would just go with a solid up pipe. I've seen an invidia in person in the past and it seemed like a nice piece. Would be a good idea to heat wrap it before installation. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
otter4x4 Posted December 8, 2012 Share Posted December 8, 2012 My Invidia went in easily (30 mins with the DP and header removed while installing Agency Power header at the same time as the UP), quickened boost response, and didn't break the bank. My car has 3 different brand exhaust components (AP header, Invidia DP & UP, SPT cat back) and they all have worked very well together. Link to comment Share on other sites More sharing options...
robitrice Posted December 8, 2012 Share Posted December 8, 2012 perrin solid is a real quality piece and fits perfect. i recommend it Link to comment Share on other sites More sharing options...
EJ25subie05 Posted December 8, 2012 Share Posted December 8, 2012 theres a sti up pipe on nasioc right now. there always there Link to comment Share on other sites More sharing options...
StoplightAssassin Posted December 8, 2012 Share Posted December 8, 2012 STi ups have shown to flow less than an aftermarket up. No troubles whatsoever with my Perrin up. Link to comment Share on other sites More sharing options...
05wagongt Posted December 8, 2012 Author Share Posted December 8, 2012 perrin solid is a real quality piece and fits perfect. i recommend it will new stock gaskets work, or will i need a different set? Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted December 8, 2012 I Donated Too Share Posted December 8, 2012 on an uppipe, you want to change gaskets every time you disconnect. High heat area Link to comment Share on other sites More sharing options...
05wagongt Posted December 8, 2012 Author Share Posted December 8, 2012 on an uppipe, you want to change gaskets every time you disconnect. High heat area i know that, i was asking are stock ones ok or should i get a different set of gaskets? Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted December 8, 2012 I Donated Too Share Posted December 8, 2012 stock is fine, as someone already stated Link to comment Share on other sites More sharing options...
05wagongt Posted December 8, 2012 Author Share Posted December 8, 2012 stock is fine, as someone already stated i was checking, because he said he said stock with the sti pipe....im getting a perrin... thank you for the help...i cant wait to get my car back so i can get it on.... Link to comment Share on other sites More sharing options...
