Eliminating Intercooler
grizzlyfarmer2
  • Replies 59
  • Created
  • Last Reply
Its not that I would want to eliminate the intercooler. Its just that I'm curious as to what would happen. Or if anyone has ever tried. And also as to what the air temp is right after the turbo. With the volume of air moving through the turbo I couldnt imagine the cold side being that much warmer than ambient. If you have never tried how can you be sure it wouldnt work I know of a lot of tractors that don't use an intercooler although they are diesels.
They used to run intercooler-less gas cars in the 80s. They would heat soak like crazy, and you'd have to tune them extremely conservatively to avoid detonation. Like to the point where you wonder why you have a turbo.
You "could" do it, but it would be completely pointless and you'd need to do extremely careful tuning so as not to blow it up. I'm not sure that the 2.5 is built durably enough, old turbo motors were tanks (or they blew up).
intercoolers are for pussies. I run a straight pipe from the turbo to the intake manifold. I only do this when I'm washing the car because I don't want to get any soap in the IC, nor do I want it getting into the turbo or manifold so I block them with a pipe.
You can definitely remove the IC. Just keep boost very low.
The 91-94 Legacy Turbo had no intercooler. Throttle response was awesome. It drove like a much larger N/A engine than the small turbocharged engine it was. 160hp, 180ft-lbs at ~6psi. The caveat, however, was that the engine was EXTREMELY overbuilt, far beyond the engines of today. Closed deck, oil squirters that would pump oil onto the back of the piston for cooling, forged rods and high pressure cast pistons, and a relatively low compression ratio. Arguably the "strongest" and best Subaru engine ever built.
If you expect to crank up boost and actually try to make substantial power, you'll end up in total fail. You will HAVE to supplement the lack of intercooler with some type of liquid injection (either alky or meth) to manage intake temperatures. I'm typically opposed to any type of injection. It works, of course, but the costs outweigh the benefits for my type of driving (lots of potential failure points). If you are willing to live with the potential compromises, then it's a great solution for you.
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
some people say you can just use meth with no intercooler...but im pretty sure you'll go through the meth as much as your gas tank
It's been done. It requires some pipe work, and some knowledge, but it works. Clearly, it's more appropriate for a track car.
So say I run 10ft of tubing with no intercooler would I expect ridiculous lag or is the intercooler the cause of the lag? I'm just trying to better understand the intercooler and everyoen here has such great opinions!
poor response is caused by pressure drop in the core, and without an IC the air is hot, I.E. less dense, I.E. more prone to detonation, I.E. need for retarding timing, I.E. no performance, I.E. no point in having a turbo, I.E.
Lag is actually the time it takes to get the turbo rotor spinning at full speed. The larger the turbo, the larger the lag, but everyone knows that already ;)
The length of the tubing or the size of the intercooler have very little effect.
better said, I'm talking more of a "response" change. I.E. going from a TMIC to a FMIC....a little response difference
