Benaaron87 Posted January 15, 2013 Share Posted January 15, 2013 I am in desperate needing of a picture or something . I have a just done a gtb conversion but I de-pinned of of the main engine plugs . On the passenger side for jdm or drivers side for American ones there is 2 plugs at the front near the battery that connect the engine . One has 12 wires the other has 8 wires . This one is the one I need pics if the female end . Reuben hoping you would be able to help Link to comment Share on other sites More sharing options...
Benaaron87 Posted January 18, 2013 Author Share Posted January 18, 2013 Fine whoever gets me a picture that pays off I will give the m through PayPal $50 aud Link to comment Share on other sites More sharing options...
twisty Posted January 18, 2013 Share Posted January 18, 2013 you didnt put any info on the car. what year are you talking about? it may be different from year to year, especially if i give you a pic of my 95 and you have a 98 or 99. also, mine isnt RHD or jdm anything, so there may be a difference there. Link to comment Share on other sites More sharing options...
Benaaron87 Posted January 18, 2013 Author Share Posted January 18, 2013 Apart from the face its in the second gen section but Sorry my bad . The car is a 1996-98 jdm legacy gtb running ej20r I'm pretty sure and an 4eat Link to comment Share on other sites More sharing options...
Benaaron87 Posted January 18, 2013 Author Share Posted January 18, 2013 Rhd lhd should make that much of a difference the plug should be the same Link to comment Share on other sites More sharing options...
twisty Posted January 18, 2013 Share Posted January 18, 2013 my daughter has my car until i rebuild her civic, ill see if i can take a look at mine and get a pic if its the same. kids are at their moms this weekend, not sure how soon it will be. Link to comment Share on other sites More sharing options...
Benaaron87 Posted January 19, 2013 Author Share Posted January 19, 2013 Cheers twisted Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 19, 2013 Share Posted January 19, 2013 Sorry, but the US didn't get EJ20rs unless we imported them from Japan. So most of us are not familiar with them. Aren't there any good Aussie forums that could help you? Link to comment Share on other sites More sharing options...
SpecBamf41 Posted January 19, 2013 Share Posted January 19, 2013 my fsm does cover rhd but it must just be for postal cars, sorry. BNR18g on 93oct Link to comment Share on other sites More sharing options...
Benaaron87 Posted January 19, 2013 Author Share Posted January 19, 2013 Post your pics either the way I know 3 wires got to the tps . All I need is the wire order guys . Put in atleast 100 hours so far and need something to see if I'm close . Link to comment Share on other sites More sharing options...
Benaaron87 Posted January 19, 2013 Author Share Posted January 19, 2013 What do you mean by postal wagon? Link to comment Share on other sites More sharing options...
Benaaron87 Posted January 19, 2013 Author Share Posted January 19, 2013 Monkey even the Aussie dealers knew very little about the legacys apart from basics Link to comment Share on other sites More sharing options...
Benaaron87 Posted January 19, 2013 Author Share Posted January 19, 2013 Swagon what's an fsm Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 19, 2013 Share Posted January 19, 2013 Factory Service Manual. I can send it to you if you want. I have the 90-94 manual. It has the complete wiring diagram. It probably won't help but it's worth a shot. Send me your email in a PM (private message) and I'll get it to you. I also have the 95 manual but it doesn't have the wiring section. Check this link for other FSMs: http://www.main.experiencetherave.com/subaru_manual_scans/Â I'll go outside and see if I can get a pic of my '95 EJ22E that might be useful. I just don't think that the wire colors will be the same. Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 19, 2013 Share Posted January 19, 2013 Ok, here is a pic of the engine wiring harness plugs from my Ej22E, and my EJ22T (turbo model). The first pic is my 22E, and the plugs are located on the passenger side. The second pic is the 22T and the plugs are located on the driver's sive near the battery. Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 19, 2013 Share Posted January 19, 2013 Is the plug located in this diagram? ecu pinouts for 1996 wrx: http://www.northursalia.com/modifications/misc/wiring/wiring.html Some wiring diagrams from MY92-96, MY97-98, & MY99-00 Impreza turbos: http://www.jollygreenmonster.com/pinouts.htm Hopefully you can trace the wires from the appropriate ecu pinouts and get the colors matched up with your female end of the engine harness. That's all I got. Good luck. Link to comment Share on other sites More sharing options...
Benaaron87 Posted January 19, 2013 Author Share Posted January 19, 2013 Yo monkey the first picture was pretty close on the first two lines but the bottom row of plugs is alittle different Link to comment Share on other sites More sharing options...
Benaaron87 Posted January 19, 2013 Author Share Posted January 19, 2013 If e3 plug is smaller than the one next it then yes Link to comment Share on other sites More sharing options...
Benaaron87 Posted January 19, 2013 Author Share Posted January 19, 2013 I've been going through the wiring diagrams here slowly without any luck http://www.veloce.pwp.blueyonder.co.uk/technical%201.htm Link to comment Share on other sites More sharing options...
Benaaron87 Posted January 22, 2013 Author Share Posted January 22, 2013 Ok so I've got abit of an update . Found that 3 of the wires are for the throttle position sensor now I just have to figure out where they can in relation to the plug as I'm not sure what the three colors actually are supposed to be for Link to comment Share on other sites More sharing options...
Benaaron87 Posted January 27, 2013 Author Share Posted January 27, 2013 Further update found out that 3 wires are the temper sensor and three are for the tps . Now I have to figure the last two and order for plug Link to comment Share on other sites More sharing options...
