LegacyDan Posted January 2, 2013 Share Posted January 2, 2013 ever since i fitted the turboxs fmic and kstech 73mm megamaf, i have weird cold start issues, i know i need a re-tune after fitting these parts and should have a revision this week, but i just want to confirm if it is actually from the new parts fitted and not something else. So from a cold start in the morning the car sounds very lumpy and engine shakes a lot like its going to cut out, you can hear a loud suction noise from the air filter and it takes a couple of minutes for things to idle normally. Is this normal behaviour for when the above mods have been installed? or do i have a bigger problem at hand. I assumed it was from the intake fitted with the larger Maf diameter so it has thrown the maf scaling off and car freaks out when cold. It pulls fine under boost with no knock present but is just lumpy and laggy at the moment, hopefully all is fixed with a re-tune. im afraid to drive on boost to much until i get this fixed! Ill try get a video clip of the cold idle weirdness Link to comment Share on other sites More sharing options...
ripemeat Posted January 2, 2013 Share Posted January 2, 2013 have you boost leak tested the system yet? since you have a big maf now, your fueling is going to be all out of whack and your maf scaling is going to need to be heavily adjusted. I'd boost leak test it, if that's alright and no vac leaks, get the retune and see what happens. Link to comment Share on other sites More sharing options...
LegacyDan Posted January 2, 2013 Author Share Posted January 2, 2013 ill have to get myself, borrow a regulated compressor i can use to do a leak test, i'll check out what my mechanic has. only thing i have is a bike foot pump! Link to comment Share on other sites More sharing options...
LegacyDan Posted January 2, 2013 Author Share Posted January 2, 2013 could i use something like this to build pressure? i think you can set the psi you want to inflate to, im not sure does it need to detect pressure first though before it will start pumping http://www.halfords.ie/webapp/wcs/stores/servlet/product_storeId_11101_catalogId_15551_productId_786119_langId_-1_categoryId_212481 Link to comment Share on other sites More sharing options...
ripemeat Posted January 2, 2013 Share Posted January 2, 2013 that's mad ghetto. also, with that thing running you won't be able to hear where the leak is! Link to comment Share on other sites More sharing options...
LegacyDan Posted January 2, 2013 Author Share Posted January 2, 2013 never thought of that, looks like ill have to think of something else Link to comment Share on other sites More sharing options...
LegacyDan Posted January 4, 2013 Author Share Posted January 4, 2013 found the possible culprit of weird cold start idling maybe, ill check it out in the morning and see how it starts: http://i32.photobucket.com/albums/d3/desperatedano/IMG_20130104_181719.jpg Link to comment Share on other sites More sharing options...
ripemeat Posted January 4, 2013 Share Posted January 4, 2013 lol. yeah. that'll do it. you're leaning out because of that. Link to comment Share on other sites More sharing options...
