BadBrew Posted March 13, 2013 Share Posted March 13, 2013 So I bought this nice extension but I'm stuck pretty much at the very start... I removed the cover above the cup holder, remove the only screw behind it and it stops there. The console rear side won't bodge at all. I tried to find different instructions around but they all go through to these steps which seemed pretty much straight forward.... I tried to apply pressure every way around the rear side but no go... help!?! Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted March 13, 2013 I Donated Too Share Posted March 13, 2013 Only the screw holds it in place. You are simply not pulling with enough force... You can get a big screwdriver and put it under the edge - sitting in the back of the car the screwdriver would face towards you... just put it in and gently lift up on one side - POP! do the other side if necessary... POP! Done... you'll kick yourself when you see you're just wussing out! Good luck man! Link to comment Share on other sites More sharing options...
BadBrew Posted March 13, 2013 Author Share Posted March 13, 2013 Only the screw holds it in place. You are simply not pulling with enough force... You can get a big screwdriver and put it under the edge - sitting in the back of the car the screwdriver would face towards you... just put it in and gently lift up on one side - POP! do the other side if necessary... POP! Done... you'll kick yourself when you see you're just wussing out! Good luck man! haha I did apply force on it to pull it out also tried a trim removal tool around the edge... but I guess I'm really a wuss! Will try again tomorrow in daylight Thanks Link to comment Share on other sites More sharing options...
