nismohrdbody Posted July 11, 2012 Share Posted July 11, 2012 hey guys, so i notice the other day that my power steering was getting low, so i filled it to the max level. and then i noticed my car started running like poo poo. and over a few weeks the level in the resivor goes down, and once its at the low level the car runs great. i have filled it up once or twice and it does the same thing. there are no leaks i have looked all around, no spots on the drive way ether....??? i thought i saw a post on this already but couldnt find anything when i searched. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 11, 2012 Share Posted July 11, 2012 The fluid has to be going somewhere. You must have a leak. IDK why filling it would make the car run bad. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JBird Posted July 11, 2012 Share Posted July 11, 2012 maybe you have some crud in the system. i know theres mixed opinions about doing it but maybe you should flush the system out. are you checking the levels hot or cold? Link to comment Share on other sites More sharing options...
nismohrdbody Posted July 13, 2012 Author Share Posted July 13, 2012 im checking it at cold. idk ill have to take a closer look. Link to comment Share on other sites More sharing options...
