Steve ko Posted July 30, 2015 Share Posted July 30, 2015 What advantage would removing the resonator have? I noticed some time ago mine has been replaced with a pipe (really professional job also) people I have asked can't give me an answer. Steve Link to comment Share on other sites More sharing options...
forced compression Posted July 30, 2015 Share Posted July 30, 2015 The advantage of just removing it and nothing else would be noise(maybe a little extra flow), if the entire pipe was replaced and upsize then you should flow more. Either way expect raspiness Link to comment Share on other sites More sharing options...
gto7419 Posted July 30, 2015 Share Posted July 30, 2015 A resonator allows the exhaust manufacturer to "tune" the exhaust note. Usually this involves reducing certain frequencies to reduce drone. Link to comment Share on other sites More sharing options...
BoyceWare Posted August 2, 2015 Share Posted August 2, 2015 If you decide you want to put one on check out the vibrant 1141. I don't personally have this installed, but I bookmarked it after seeing some great reviews from other legacy owners. Vibrant 1141 2.5" Ultra Quiet Resonator http://amzn.com/B000E3VHWI Link to comment Share on other sites More sharing options...
Shello007 Posted August 4, 2015 Share Posted August 4, 2015 I removed mine recently, but I have performance mufflers and DP. Needless to say, the flow was greatly improved and top end power got better. Ideally, I have my Boxer Rumble now, and it's a little contained. Link to comment Share on other sites More sharing options...
kaitanium Posted August 4, 2015 Share Posted August 4, 2015 that boxer rumble is enough to be a good reason =D Link to comment Share on other sites More sharing options...
