Bpalumbo159 Posted January 24, 2013 Share Posted January 24, 2013 Just wondering if anyone knew of a site besides ebay to find any performance parts for a 2007 legacy 2.5. And i know that people are gonna say well you should have got a gt , but i didnt so im workin with what i have. Any help would be nice. Thanks for all your help! Link to comment Share on other sites More sharing options...
Subieaction Posted January 24, 2013 Share Posted January 24, 2013 ummmmmmmmmm................. the vendors Link to comment Share on other sites More sharing options...
bomberlegacy Posted January 24, 2013 Share Posted January 24, 2013 Any of the vendors on here, Google, search on here. There isn't much you can do with a 2.5i unless you go turbo or supercharger. Or suspension upgrades. Do you have E85 fuel in your area? If so, grab a used set of GT injectors from the classifieds and get a tune for e85. That's your best bet Imo. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
Bpalumbo159 Posted January 25, 2013 Author Share Posted January 25, 2013 bomber did ou super charge you car if so what did you have to change to make it work correctly. did you have to rebuild the motor to handle itor did you slap it on your stock car. i ve done crank pulley and p/s pulley which i noticed a difference in response. ive also puttein stechs on and front and rear strut tower bars. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 25, 2013 Share Posted January 25, 2013 ummmmmmmmmm................. the vendors on here...check out the vendor forum. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bomberlegacy Posted January 25, 2013 Share Posted January 25, 2013 bomber did ou super charge you car if so what did you have to change to make it work correctly. did you have to rebuild the motor to handle itor did you slap it on your stock car. i ve done crank pulley and p/s pulley which i noticed a difference in response. ive also puttein stechs on and front and rear strut tower bars. Stock bottom end. It can handle 9-10psi fine. Which ps pulley did you get? '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
Platinum_Racing Posted January 26, 2013 Share Posted January 26, 2013 How does that 10:1 compression ratio fair with the supercharger? Is the E85 mandatory now? Just curious. Link to comment Share on other sites More sharing options...
bomberlegacy Posted January 26, 2013 Share Posted January 26, 2013 Good so far but I don't have a bunch of miles on it yet. Others have had success. 10psi is about the max they recommend on the stock bottom end due to higher compression. E85 not mandatory, but it'll help make some more power '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
frank_ster Posted January 26, 2013 Share Posted January 26, 2013 need driving around video of that car Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
