DJBRANDER Posted November 14, 2013 Share Posted November 14, 2013 So my car is overheating again.... 2.2 N/A Here's the symptoms: -Radiator is cold -overheats at only at highway speeds -Overflow is over filled (not sucking in coolant) -Not losing coolant -Top hose is warm, Bottom is cold -Thermostat was replaced a year ago -90k on the clock with a new waterpump/timing belt I dropped the car off before I went to work to have a coolant system pressure test/full check done because I didnt have time this morning. I'll keep you guys posted. Link to comment Share on other sites More sharing options...
Sumbaru Posted November 14, 2013 Share Posted November 14, 2013 Pinhole leak on head gasket. Link to comment Share on other sites More sharing options...
Idaho subaru Posted November 14, 2013 Share Posted November 14, 2013 Sounds like a flow issue. Subaru thermostat? Taking it to a subaru repair shop? Link to comment Share on other sites More sharing options...
DJBRANDER Posted November 14, 2013 Author Share Posted November 14, 2013 Pinhole leak on head gasket. I sure hope not. Why do those symptoms lead you to think of that? Sounds like a flow issue. Subaru thermostat? Taking it to a subaru repair shop? No not a Subaru Thermostat. Just an auto parts store one. Its sitting at the local firestone by my house. oh and it doesnt overheat on backroads.. just on the highway. Link to comment Share on other sites More sharing options...
DJBRANDER Posted November 14, 2013 Author Share Posted November 14, 2013 and I know this is crazy but would a clogged heater core do it? I think it happened when I put it on windshield/feet. like can 1/2 the core clog up? Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 14, 2013 Share Posted November 14, 2013 Please, I beg you, please, get an OEM Subaru thermostat. I'd make sure that isn't your issue before you go digging into anything else. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 14, 2013 Share Posted November 14, 2013 A clogged heat core wouldn't cause the issue Link to comment Share on other sites More sharing options...
DJBRANDER Posted November 14, 2013 Author Share Posted November 14, 2013 Please, I beg you, please, get an OEM Subaru thermostat. I'd make sure that isn't your issue before you go digging into anything else. thats the plan so far, is it a common issue with store brand ones for our cars? Link to comment Share on other sites More sharing options...
monkeyposeur Posted November 14, 2013 Share Posted November 14, 2013 Yes!!! Link to comment Share on other sites More sharing options...
twisty Posted November 14, 2013 Share Posted November 14, 2013 sounds like flow restriction to me, id check out that tstat first. why, you ask? on the highway, you have the rpms up over 2400, and normally with the circulation the wind alone is enough to keep the engine cool, so head gasket issues are masked a bit by the fact that it doesnt overheat until you get onto the city streets. when you have restricted flow, youll have cooling at lower rpms and with minimal (and not constant) load on the engine. ive had the same symptoms on vehicles with bad pumps (messed up impellers), clogged water lines as well as clogged radiators. Link to comment Share on other sites More sharing options...
DJBRANDER Posted November 14, 2013 Author Share Posted November 14, 2013 sounds like flow restriction to me, id check out that tstat first. why, you ask? on the highway, you have the rpms up over 2400, and normally with the circulation the wind alone is enough to keep the engine cool, so head gasket issues are masked a bit by the fact that it doesnt overheat until you get onto the city streets. when you have restricted flow, youll have cooling at lower rpms and with minimal (and not constant) load on the engine. ive had the same symptoms on vehicles with bad pumps (messed up impellers), clogged water lines as well as clogged radiators. That makes sense. The shop called me (im at work till 7 ugh) and they said there was a blockage, the thermostat wasnt working... and they wont continue testing till its replaced. So hopefully its just that. I wish I could just do it myself haha. Theres that trade off, when I had my own shop I could tinker with it and fix it, but now that I have an office job I dont have the time anymore. Link to comment Share on other sites More sharing options...
DJBRANDER Posted November 14, 2013 Author Share Posted November 14, 2013 oh by the way, you guys are awesome and thank you so much for the help! I'll keep you updated. Link to comment Share on other sites More sharing options...
DJBRANDER Posted November 15, 2013 Author Share Posted November 15, 2013 ALRIGHT, so they said that it was a faulty thermostat stuck 1/4 way open. Thank buddy jesus for that one! Stupid junky ass parts. Thanks so much you guys. Link to comment Share on other sites More sharing options...
