Mlefrancis Posted January 12, 2013 Share Posted January 12, 2013 97 legacy won't stop beeping. The door switches all changed. Seat belt works Dose any one have a fix. short of removing the gage cluster and cutting the wire Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 12, 2013 Share Posted January 12, 2013 From subaruoutback.org (search disable seat bet chime subaru): "1. Turn engine on (may work in ACC, but definitely when on). 2. Within 30 secs of ignition, clip/unclip seatbelt 20 times. That's it, no on/off cycles to do. This worked first time for my car - 05 OBXT. Setting will last until the microprocessor is reset or battery disconnected. For a temp disable of chime, do the clip/unclip cycle 3 times only, will reset once ignition is turned off again. Handy for the disgruntled passenger who refuses to buckle up." If you disconnect your battery you will have to do this again. There is also a way to permanently disable the chime: http://www.subaruoutback.org/forums/104-gen-4-2010-present/43417-seatbelt-chime-removal.html Hope this helps. Link to comment Share on other sites More sharing options...
