ChefRacer Posted November 27, 2011 Share Posted November 27, 2011 Hey guys, so I hooked up an aftermarket mid/y pipe, including the stock donut gasket kinda wedged between the dp and mid pipe, but I cant quite seem to get a tight seal. Do most of you guys keep the donut gasket and spring bolts, or switch up to just a standard 3" exhaust gasket and a couple of normale bolts. I'm just a bit worried that since there is no flex pipe, that the spring bolts are necessary to give a bit of flex to the exhaust. I still have rubber exhaust hangers so I know those will flex a bit. I appreciate your opinions. Thanks Link to comment Share on other sites More sharing options...
ChefRacer Posted November 28, 2011 Author Share Posted November 28, 2011 Doesn't anybody know this, I'm just trying to figure out what I can do so my 5 mo old baby isn't inhaling exhaust fumes anytime I'm sitting at a stop light with the windows open. Thanks alot for your help. Link to comment Share on other sites More sharing options...
hal9e3 Posted November 29, 2011 Share Posted November 29, 2011 I'm assuming your mid/Y is 3". Here's what I did to fix it and some alternative approaches. Link to comment Share on other sites More sharing options...
ChefRacer Posted November 29, 2011 Author Share Posted November 29, 2011 Well actually both the dp and the mid/y are 3", I'm just not sure whether I should do a solid connection or another of these silly donut gasket/spring bolt setups Link to comment Share on other sites More sharing options...
hal9e3 Posted November 29, 2011 Share Posted November 29, 2011 Not sure where to get a 3" donut. The DP didn't come with one? The donut's there for a reason - to allow some play between the engine/DP and the rest of the exhaust. However, if the junction can't be sealed up that way then a regular gasket is the way to go. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted December 2, 2011 Share Posted December 2, 2011 The donut is only used for a stock-style downpipe. If both your dp and mid-pipe are 3", then use a 3" gasket with regular bolts. Whether or not a flex section is needed is a different story. Link to comment Share on other sites More sharing options...
ChefRacer Posted December 2, 2011 Author Share Posted December 2, 2011 Thanks for your help guys, I'm going to try to source out a 3" gasket today. Link to comment Share on other sites More sharing options...
tildowns Posted December 7, 2011 Share Posted December 7, 2011 Hey Chefracer, installed the cans today. Worked out great and got a great boxer rumble.....good luck w/ your tubes. Link to comment Share on other sites More sharing options...
