Tbizz Posted April 8, 2013 Share Posted April 8, 2013 Hi all, I did a bit of searching to no avail. My passenger door sounds really hollow. I'm not sure if there's something wrong with it or if its common. I'm thinking about taking the door panel off if it's a common thing otherwise I'll see if they'd cover it under Warranty but something tells me that won't be worth it. Anyone else having this issue? Link to comment Share on other sites More sharing options...
acumenhokie Posted April 8, 2013 Share Posted April 8, 2013 I will go check mine specifically for this but it sounds like something is lose inside the door panel to me too. Link to comment Share on other sites More sharing options...
DrD123 Posted April 8, 2013 Share Posted April 8, 2013 Something is amiss there - my front and rear doors sound about the same as your rear did - pretty solid. Not sure what it could be - have you pulled the interior panel to see if anything is loose? Also - is the weather stripping, etc. in good shape on that door? (specifically, there are two bumpers on the edge of the door - one on the lower corner, and one about half-way up - if one of those is missing, the door might ring like that...) Link to comment Share on other sites More sharing options...
PSUice944 Posted April 8, 2013 Share Posted April 8, 2013 SAME sound in my 2010. I haven't wanted to take the door card off just to "explore" since technically nothing is really broken. And yes, it seems to be ONLY the front passenger side door, that "hollow metal panel" sound when closing it. I seem to rememver trolling through the threads and seeing that someone else referred to the same thing like many of us have the same issue. Hopefully someone more knowledgable will chime in? Link to comment Share on other sites More sharing options...
Subie_Mick Posted April 8, 2013 Share Posted April 8, 2013 Mine did this - These doors are the first framed door that Subaru has done on the Legacy - From what I was told the doors ar a 1 piece door, meaning that you cannot order a door skin. What is causing the vibration "PONG" type sound when you close the door is the skin is glued onto the frame in certain section to reduce vibration. Your glue has broken loose. They took my door apart and reapllied glue and "addtional sound deadening" and the PONG is gone. Link to comment Share on other sites More sharing options...
Tbizz Posted April 8, 2013 Author Share Posted April 8, 2013 Thanks for that. Has anyone taken the door panel apart to fix this and how did it go? Link to comment Share on other sites More sharing options...
acumenhokie Posted April 8, 2013 Share Posted April 8, 2013 I can confirm that my front passenger sounds "solid" (like what your rear sounded like). I'm thinking we should name this the "PONG Fix" going forward. Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted April 8, 2013 Share Posted April 8, 2013 out of curiosity, does it sound the same when the window is up all the way? www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
KingOfTheWorld Posted April 9, 2013 Share Posted April 9, 2013 Yup another one of the 20000 issues that came with my 2010 Legacy that Subaru has yet to fix. The drivers side door sound solid while the passenger side door sounds like you said "hollow". ffs Subaru Link to comment Share on other sites More sharing options...
hmmrdwn Posted April 9, 2013 Share Posted April 9, 2013 :icon_arroLooks like Bobgee is back. Link to comment Share on other sites More sharing options...
faded-a-fool Posted April 9, 2013 Share Posted April 9, 2013 :icon_arroLooks like Bobgee is back. There is another new member with 3.6R in his name that bares more of a resemblance Link to comment Share on other sites More sharing options...
hmmrdwn Posted April 9, 2013 Share Posted April 9, 2013 There is another new member with 3.6R in his name that bares more of a resemblance I think bob uses multiple log in names. Link to comment Share on other sites More sharing options...
Tbizz Posted April 9, 2013 Author Share Posted April 9, 2013 out of curiosity, does it sound the same when the window is up all the way? Yeah, it makes the same sound with the window up. Link to comment Share on other sites More sharing options...
seiyafan Posted April 9, 2013 Share Posted April 9, 2013 Once I took all the door panels off to apply sound deadening materials, not sure if it reduced any road noise, but door closing sounded like closing a bank vault. Link to comment Share on other sites More sharing options...
Tbizz Posted April 12, 2013 Author Share Posted April 12, 2013 I took it to the dealer to check it out since it's under warranty. They said they're going to have to take it in again and bring it to the body shop to fix. The guy did a bad job of explaining but he said something along the lines of...The bond between the door and the door frame has come loose. I'm bringing it in in a couple weeks. Hopefully I'll be able to explain it better and get a feel for what it would cost out of warranty. Link to comment Share on other sites More sharing options...
GTEASER Posted April 12, 2013 Share Posted April 12, 2013 How many miles do you have on it? I would not settle for "out of warranty". Your issue is clearly not something that you did, it's poor build issue. Make SOA take care of it. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
colombo Posted May 28, 2013 Share Posted May 28, 2013 Hi all, I did a bit of searching to no avail. My passenger door sounds really hollow. I'm not sure if there's something wrong with it or if its common. I'm thinking about taking the door panel off if it's a common thing otherwise I'll see if they'd cover it under Warranty but something tells me that won't be worth it. Anyone else having this issue? I have the same issue with my driver's door. Did you get it fixed? If yes, what they have done? Thank you. Link to comment Share on other sites More sharing options...
Tbizz Posted May 28, 2013 Author Share Posted May 28, 2013 I ended up bringing it back to the dealership under Warranty. The guy at the dealership said that it was probably somebody sleeping in line at the assembly plant forgot to glue the door. He said there was a strip of glue between the door and something else that was missing. Good luck. Link to comment Share on other sites More sharing options...
colombo Posted May 28, 2013 Share Posted May 28, 2013 I ended up bringing it back to the dealership under Warranty. The guy at the dealership said that it was probably somebody sleeping in line at the assembly plant forgot to glue the door. He said there was a strip of glue between the door and something else that was missing. Good luck. Thank you. I still have planty of warranty left. So I will ask them to look into this at next oil change. Was it a quick fix or you had to leave the car at service for a day or so? Link to comment Share on other sites More sharing options...
Tbizz Posted May 29, 2013 Author Share Posted May 29, 2013 You're welcome. I had to leave it for a day. I was able to get a loaner. Link to comment Share on other sites More sharing options...
levihamernik Posted July 30, 2013 Share Posted July 30, 2013 Sitting here at the stealership getting an oil change. Noticed that my passenger door has this same issue so I asked them to take a look at it. They said it would be $55 for them to look at it and figure out what's wrong with it. :mad: Link to comment Share on other sites More sharing options...
UD202 Posted January 19, 2017 Share Posted January 19, 2017 I just got my 2011 Legacy 3.6R and I'm having the same hollow noise issue. Is there something that I can fix myself or do I need to go to the dealer to fix it? Anybody know what the cost is? Link to comment Share on other sites More sharing options...
capttris Posted January 19, 2017 Share Posted January 19, 2017 I guess I missed this thread back in 2013, but my passenger front door has the same hollow PONG sound when I close it. It always did, from day one. I figured it was normal. Too late now that I am long out of warranty. I fly solo 99% of the time so it's not a big deal I suppose. Link to comment Share on other sites More sharing options...
FLlegacy Posted January 20, 2017 Share Posted January 20, 2017 I bet a two part epoxy would do, if someone could tell use where to glue. Link to comment Share on other sites More sharing options...
