discojon Posted August 10, 2014 Share Posted August 10, 2014 While changing my blower motor I heard this thing making noise. Seems to be a solenoid / actuator or some type that is constantly cycling. Located passenger foot well on the side nearest transmission runner. What is it and what does it do? http://img.tapatalk.com/d/14/08/11/u7yneza6.jpg Link to comment Share on other sites More sharing options...
LeGiT_Flat4 Posted August 10, 2014 Share Posted August 10, 2014 I think you are look for this: part # 72131AG24A Check out this thread. http://legacygt.com/forums/showthread.php/sound-inside-dash-turn-off-car-190728p2.html Post #51 has video and pics Link to comment Share on other sites More sharing options...
discojon Posted August 10, 2014 Author Share Posted August 10, 2014 Thanks. Unfortunately the problem with mine is the actuator directly below the one that controls the vents. It seems to have a lever connected to an arm that goes into the center console. All of my HVAC stations work as does recirc/ outside air Link to comment Share on other sites More sharing options...
discojon Posted August 10, 2014 Author Share Posted August 10, 2014 Looks to be the mix door actuator. My car has the auto HVAC. 72131AG26A Link to comment Share on other sites More sharing options...
discojon Posted August 10, 2014 Author Share Posted August 10, 2014 Weird. Both driver / passenger dual zone climate works just fine. The servo is acting like it can't find center. Like a pot is going bad it seems like. Link to comment Share on other sites More sharing options...
DrD123 Posted August 10, 2014 Share Posted August 10, 2014 We had the drivers side mixer motor flip out on our Odyssey - it would flutter back and forth. I took it apart, cleaned up the contacts, etc, reassembled and it's been fine ever since. Not sure if the Subaru ones come apart easily, but from the picture it looks like it comes apart the same way the Honda one does (just pull back the plastic clips on the sides and the two halves of the case should come apart) Link to comment Share on other sites More sharing options...
discojon Posted August 11, 2014 Author Share Posted August 11, 2014 It seems to have stopped. I just ran the Self diagnosis on the HVAC and everything passed So I'm not going to worry about it. Link to comment Share on other sites More sharing options...
