doobaruGT Posted October 9, 2012 Share Posted October 9, 2012 So I have a mystery issue. My passenger HID works, but only sometimes. I received a new bulb and installed it with the existing Ballast on Saturday. It didn't work. So I swapped the ballast, still no light. So I checked the fuse...fuse looked good but I swapped it anyway...Light worked! I said to myself, if this is a fuse issue I'm just going to use the old ballast, and I reinstalled the old ballast...light didn't work again. Swapped new ballast in again and it worked! Now when I drive, sometimes the light comes on and other times it doesn't. I'm not sure where to go from here:spin: Need suggestions...GO!... Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
doobaruGT Posted October 9, 2012 Author Share Posted October 9, 2012 If it is a ground, where can I find the ground to fix it? Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
