GFB hybrid BOV
if your talking about the hex bolt on top that adjust the internal spring not the amount that vents
StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap
Yea now that I look at it, it is missing the collar that it seems is what turns the response ones. Thank you for your help. Do you know, when running an EBCS, what is the point of adjusting the spring pressure in the wastegate?
An ebcs doesn't control your bpv spring you might be thinking of your Wastegate on turbo
