Legacy05 Posted July 28, 2005 Share Posted July 28, 2005 Not too long ago I had a fuel injector replaced on my car due to a P303 cylinder misfire code. I was just curious, if at idle, if it is normal for the car to shake a bit (idle a bit rough at times). It was really bad when the fuel injector went tits up. So I have no idea if what I am feeling now is considered "Normal" . I am running AP Stage 1. Thanks. Link to comment Share on other sites More sharing options...
melayout Posted July 28, 2005 Share Posted July 28, 2005 Yes it is totally normal. Been doin it since day one and I love it. Like sitting on an ICBM that's about to launch. Dr. StrangeLove I keed I keeed Link to comment Share on other sites More sharing options...
Deer Killer Posted July 28, 2005 Share Posted July 28, 2005 It's normal like other "features" are normal. So your engine isn't broken compared to others, but not any better than that.. Link to comment Share on other sites More sharing options...
melayout Posted July 28, 2005 Share Posted July 28, 2005 Deer Killer - The shake is a characteristic of the Subaru boxer engines. I'm not saying that it is a problem that you just have to cope with. I keed I keeed Link to comment Share on other sites More sharing options...
Deer Killer Posted July 28, 2005 Share Posted July 28, 2005 Deer Killer - The shake is a characteristic of the Subaru boxer engines.Correction, the shake is a characteristic of the subaru boxer engine when there is a misfire/bad mixture in a cylinder. My old carburated honda used to also get that shake, not the boxer shake, but a tranverse inline-4 one. Readjusting the idle mixture fixed it. We don't have an idle mixture needle. Link to comment Share on other sites More sharing options...
melayout Posted July 28, 2005 Share Posted July 28, 2005 Search www.nasioc.com for "engine shake" and you'll see what I'm talking about. I keed I keeed Link to comment Share on other sites More sharing options...
melayout Posted July 28, 2005 Share Posted July 28, 2005 Legacy05 - Does the shake go away if you hold the gas at 2000RPM? If so then it is just a mechanical harmonic effect happening at that lower RPM and nothing to worry about. I keed I keeed Link to comment Share on other sites More sharing options...
Legacy05 Posted July 28, 2005 Author Share Posted July 28, 2005 Thanks!!! I'll just stop being paranoid about it and accept it Btw, car just turned 16k miles woo woo. Link to comment Share on other sites More sharing options...
Legacy05 Posted July 28, 2005 Author Share Posted July 28, 2005 Legacy05 - Does the shake go away if you hold the gas at 2000RPM? If so then it is just a mechanical harmonic effect happening at that lower RPM and nothing to worry about. I will give that a try today when I go home, I don't feel anything off the top of my head. That's with the A/C off .... (I can feel the A/C doing its magic driving around sometimes). Link to comment Share on other sites More sharing options...
LEGGTLTD Posted July 28, 2005 Share Posted July 28, 2005 Today is the second time that my car died at a stop light with the AC on with outside temp.s in the 90's It idles rough with the AC on, but idles fine with the AC off. Does anyone have any thoughts as to this problem? Thanks, Will Megan header,Perrin TMIC, TD06-20G,AEM CAI, Lachute DP, Avo BOV, BC Coilovers, Magnaflow catback, Hawk HPS pads, Stoptech lines, Snow WI Link to comment Share on other sites More sharing options...
melayout Posted July 28, 2005 Share Posted July 28, 2005 Weak battery/alternator? Electrical hiccup in the A/C causing a short or something? I keed I keeed Link to comment Share on other sites More sharing options...
Legacy05 Posted July 28, 2005 Author Share Posted July 28, 2005 Today is the second time that my car died at a stop light with the AC on with outside temp.s in the 90's It idles rough with the AC on, but idles fine with the AC off. Does anyone have any thoughts as to this problem? Thanks, Will I'd take it in ... it will be covered, its in the 110+ here and my car is fine with the A/C on. Link to comment Share on other sites More sharing options...
LEGGTLTD Posted July 28, 2005 Share Posted July 28, 2005 I'd take it in ... it will be covered, its in the 110+ here and my car is fine with the A/C on. I am hesitant to take it in since it is at Stage 2 with Ecutek tune. I'm afraid the dealer would blame it on my mods and charge me what ever ridiculous fees to fix it... Megan header,Perrin TMIC, TD06-20G,AEM CAI, Lachute DP, Avo BOV, BC Coilovers, Magnaflow catback, Hawk HPS pads, Stoptech lines, Snow WI Link to comment Share on other sites More sharing options...
njadventure Posted August 5, 2005 Share Posted August 5, 2005 I'm also noticing the rough idle. I only had the OB for a week. Link to comment Share on other sites More sharing options...
