max_bobby Posted January 7, 2013 Share Posted January 7, 2013 Anyone have this issue. The driver DRL isn't working. When I turn on the full light system, the DRL bulb works fine. What could it be? Link to comment Share on other sites More sharing options...
max_bobby Posted January 17, 2013 Author Share Posted January 17, 2013 Update. Still no dice. I noticed that when I put on the high beams, the driver side doesn't work. Link to comment Share on other sites More sharing options...
AkumaMax Posted January 17, 2013 Share Posted January 17, 2013 Check your fuses. If not maybe try replacing the bulb. Link to comment Share on other sites More sharing options...
nstg8r Posted January 17, 2013 Share Posted January 17, 2013 could be the drl relay Link to comment Share on other sites More sharing options...
RabidWombat Posted January 18, 2013 Share Posted January 18, 2013 Update. Still no dice. I noticed that when I put on the high beams, the driver side doesn't work. Your high beam bulb is burned out.  2008-2009 use the high beams for DRL. Link to comment Share on other sites More sharing options...
FJuan Posted January 18, 2013 Share Posted January 18, 2013 Replace bulb. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
max_bobby Posted January 19, 2013 Author Share Posted January 19, 2013 Aren't the DRL bulb and the high beam bulb the same? DRL bulb lights up when I have the full lighting system on. Link to comment Share on other sites More sharing options...
RabidWombat Posted January 19, 2013 Share Posted January 19, 2013 Aren't the DRL bulb and the high beam bulb the same? Correct. I think something is getting lost in translation. What do you mean full lighting system? Actually, a quick picture might be helpful.  Here are the settings -- Result: Everything off -- High beams at low wattage Parking lights -- High and low beams off Headlights on -- Low on, high off High beams -- Low on, high full brightness Link to comment Share on other sites More sharing options...
max_bobby Posted January 19, 2013 Author Share Posted January 19, 2013 First pic is just the drl, you can see the driver side is out. (joy)Â 2nd pic is with the full light system on, with fogs. Â 3rd pic is with the high beams on, you can see the passenger side is brighter than the driver side. Link to comment Share on other sites More sharing options...
max_bobby Posted January 19, 2013 Author Share Posted January 19, 2013 Update. No DRL's period, or highs beams. Link to comment Share on other sites More sharing options...
max_bobby Posted January 19, 2013 Author Share Posted January 19, 2013 When the take out the wiring with the bulb attached, as though I am going to change the bulb. The bulb will work when I put the headlights on, provided that it is outside of the headlight compartment. Link to comment Share on other sites More sharing options...
max_bobby Posted January 19, 2013 Author Share Posted January 19, 2013 Last but not least, the fog lights no longer working. They wont even illuminate on the dashboard, meaning the the green indicator light does not show they are on. Link to comment Share on other sites More sharing options...
AkumaMax Posted January 20, 2013 Share Posted January 20, 2013 Again Check fuses and REPLACE BOTH HIGH BEAM HEADLIGHTS!!!!!! Link to comment Share on other sites More sharing options...
max_bobby Posted January 20, 2013 Author Share Posted January 20, 2013 fuses checked, and double checked. Bulbs changed, still no dice. Link to comment Share on other sites More sharing options...
AkumaMax Posted January 21, 2013 Share Posted January 21, 2013 well then if that was all checked there is only one other thing I can think of. The DRL Module. Under your steering wheel above the left pedal. I'm guessing you need a new one. IMO take it to the Dealer I would think your still under warranty? Link to comment Share on other sites More sharing options...
max_bobby Posted January 22, 2013 Author Share Posted January 22, 2013 Solution. Suggestion was to put back the stock bulbs, as I had the stocks (high beams/fog lights) replaced about three years ago. The replacements did not look burnt out at all. Put the stocks back in, and they all work now. I don't understand, but it works. Strange. Thanks to everyone for help. You guys rock. Link to comment Share on other sites More sharing options...
AkumaMax Posted January 24, 2013 Share Posted January 24, 2013 Even though a bulb looks fine there might be a problem with the bulb that cannot be seen Link to comment Share on other sites More sharing options...
