MikeNH Posted April 2, 2010 Share Posted April 2, 2010 I also installed foglamps today and they seemed a bit more involved than I gathered from the instructions, but it's still pretty easy. For starters, I could not get the blank trim pieces off from the front of the bumper with any of my trim tools. I ended up pulling down the splash shield below each section to access the trim (and I needed them down later as well). To drop the shield, I removed two of these: http://i15.photobucket.com/albums/a370/03NHSilvy/Subaru/Foglamps/DSCF0043.jpg I have a special pair of pliers made to remove these but again, a normal pair of needlenose pliers or even 2 flatheads used together will free the center pin. Just pull down on it enough to make the head pop out and then pull the whole pin out. Now the shield can be pulled down. I should also add that even doing this, it was a bit tight and I scratched my hand to hell. Either be ok with this or wear gloves. To remove the blank trim, I reached under to the tab on the inner portion of the panel (pointing toward the center). There are two clips you need to release while pushing outward: http://i15.photobucket.com/albums/a370/03NHSilvy/Subaru/Foglamps/DSCF0039.jpg With the inner portion freed, you can pull the trim out from the outer clips: http://i15.photobucket.com/albums/a370/03NHSilvy/Subaru/Foglamps/DSCF0038.jpg Here is the taped up plug on the passenger side. Driver side is similar: http://i15.photobucket.com/albums/a370/03NHSilvy/Subaru/Foglamps/DSCF0044.jpg Better view of plug: http://i15.photobucket.com/albums/a370/03NHSilvy/Subaru/Foglamps/DSCF0041.jpg Take the metal clip nut and install it with the ridge facing to the FRONT. This seems weird but it's how it works. I reached around from the area that the fake "grill" part of the foglamp trim will cover. It just pushes on. Installing the foglamp itself again is where I had to go through the splash shield, there was no other way I could figure out how to make it go in. The lamps are not marked left/right as best I could tell but from previous experience, the connector on the light always pointed downward so I used that, along with putting the manufacturer name (Valero I think) at the 12:00 position. After the light was placed behind the panel from underneath, I reached around from the "grill" area again and picked up the light, sat the taps (they look like screws go in them, but there are none) into slots on the outer part of the bumper than seated the inner ones. There is a pin for the bottom inner one to sit on/in and the top inner one is secured with the supplied 10mm bolt. You'll need a ratchet or ratcheting wrench to make this easy to tighten. http://i15.photobucket.com/albums/a370/03NHSilvy/Subaru/Foglamps/DSCF0042.jpg After both lamps are installed, slide the outer portion of the new trim panels into the bumper and push in the clips, moving inward. The next thing I did was the switch. Pull down and remove the fuse panel door and reach up and push off the black trim panel. Remove the two phillips screws and pull down this portion of the dash. http://i15.photobucket.com/albums/a370/03NHSilvy/Subaru/Foglamps/DSCF0046.jpg I couldn't get a good picture of removing the switch, but this takes some finesse. Look at your new switch to see where the clips are. Once released, the switch pulls out from behind the panel and the new one pushed in, plugged in and then put the dash back together. http://i15.photobucket.com/albums/a370/03NHSilvy/Subaru/Foglamps/DSCF0047.jpg Last is the relay underhood. It is the blue one that is not seated in this pic: http://i15.photobucket.com/albums/a370/03NHSilvy/Subaru/Foglamps/DSCF0048.jpg Turn the headlights on (they won't work with just parking lights on) and enjoy: http://i15.photobucket.com/albums/a370/03NHSilvy/Subaru/Foglamps/DSCF0049.jpg Government does not solve problems; it subsidizes them -Ronald Reagan Link to comment Share on other sites More sharing options...
tt6 Posted October 3, 2010 Share Posted October 3, 2010 I just did this install and want to thank you for this write-up, it saved me ALOT of time. Your suggestion of pulling down the splash shield to remove the trim pieces AND to install the fog light housing is the only way to go! It makes this install so much easier than following the Subaru Instructions. Thanks!!! Link to comment Share on other sites More sharing options...
MikeNH Posted October 5, 2010 Author Share Posted October 5, 2010 I'm glad it finally helped someone! I was beginning to wonder- I posted it back in April and didn't get any hits. Government does not solve problems; it subsidizes them -Ronald Reagan Link to comment Share on other sites More sharing options...
themlruts Posted December 13, 2010 Share Posted December 13, 2010 i want to get them but there are a little pricey Link to comment Share on other sites More sharing options...
darknes Posted December 31, 2010 Share Posted December 31, 2010 Hey mike thanks for the write up. I will be doing this install soon. Moms wanted to front the fog light money for Xmas. Link to comment Share on other sites More sharing options...
Magic Marker Posted December 31, 2010 Share Posted December 31, 2010 Nice write up. I'm lazy and just had the port installed it. 2011 Volvo S60T6 & 2013 Volvo XC60T6 Polestar Link to comment Share on other sites More sharing options...
MikeNH Posted January 1, 2011 Author Share Posted January 1, 2011 Nice write up. I'm lazy and just had the port installed it. Thanks! I bought mine off the showroom floor and tired to get them to do fogs as part of the deal but they wouldn't budge and quoted me like $450 installed or something insane. The foglamps and mirror were maybe 2-3 hours of work, stopping to take pictures and notes to do these write-ups. Government does not solve problems; it subsidizes them -Ronald Reagan Link to comment Share on other sites More sharing options...
seiyafan Posted January 29, 2011 Share Posted January 29, 2011 thx for the writeup, my dealership quoted me $355 for parts+install, i am still deciding... btw, any way to turn on/off fog light independently? Link to comment Share on other sites More sharing options...
MikeNH Posted February 4, 2011 Author Share Posted February 4, 2011 $355 isn't too terrible. I think the kit was $250. But no, they only will come on with low beams and shut off with high beams or if you turn to parking lights. Government does not solve problems; it subsidizes them -Ronald Reagan Link to comment Share on other sites More sharing options...
seiyafan Posted February 4, 2011 Share Posted February 4, 2011 I finally bought the kit and decide to install myself. I saw a couple of threads on how to make fog lights independent but none of them is for 2010/11 models, that's why i asked. =) Link to comment Share on other sites More sharing options...
hmmrdwn Posted September 16, 2011 Share Posted September 16, 2011 Local dealer had a pair in stock so I bought them. Thanks to this thread I was able to pop them in fairly quickly. Ran into trouble with the dash switch that other knuckleheads like me should be aware of...get enough light to see where to pry it apart. I (doh!) ended up prying on the ones to get into the switch itself, not the ones keeping it on the dash panel. Oh well, it went into the garbage anyway. A couple notes...like someone else mentioned, wear gloves. The plastic retaining pins that stay on the underpanel cut your hands up pretty good. These are Valeo fog lights. They make fogs for numerous companies. Our Saab 9-3 had Valeo fogs that were pretty substantial units. These don't seem to be the same quality, but installed much easier. The 9-3 need the dealer to go in with the computer and set a default. It also required almost the entire front clip to be removed. Again, thanks for sharing the great pictures. Link to comment Share on other sites More sharing options...
cwa107 Posted September 18, 2011 Share Posted September 18, 2011 Just wanted to say "thanks" to MikeNH for his detailed write-up. This was much easier than it has been to do the same on Honda's I've owned, but there's still a few places where the instructions could be a little more clear and Mike's post helped immensely. I just want to caution anyone doing this to be gentle with the tabs on the foglight assembly - they are brittle and will break easily. Unfortunately, I learned this the hard way - I had the fog light oriented in the hole badly and broke one of mine off. I was able to fix it (hopefully permanently) with a bit of generous Krazy Glue, but I could have easily prevented it by taking a little more care with the way the tabs seat into the bumper cover. Also, heed Mike's advice on opening the apron below the bumper cover. It takes just a minute, and since the lamps have to be installed BEHIND the bumper (not all that clear from the instructions), you definitely want to be able to have plenty of access - and this will do the trick. As far as effectiveness (in case anyone was wondering), the difference is dramatic - I would say "night and day", but that might come across as a rather bad pun Seriously though, the projectors are decent headlights, but they have a very harsh cutoff and the fog lights do a great job of filling in the gaps. Well worth the $215 or so it will cost you through one of the online dealers that sell Subaru parts. We still love our Legacy after a year and a half or so of ownership. Would buy this car again in a heartbeat. Link to comment Share on other sites More sharing options...
greyowl Posted October 29, 2011 Share Posted October 29, 2011 Anyone know if this is the same for the 2012 legacy? I think it is but not sure. Thanks for the info. Link to comment Share on other sites More sharing options...
MikeNH Posted October 29, 2011 Author Share Posted October 29, 2011 Should be. There was some question as to the switch changing location- seems that Legacy models with factory installed fogs have a switch on the turn signal lever whereas the add-on kit you buy (or that the dealer/distributor may use) will have it pictured like here on the mirror control panel. Government does not solve problems; it subsidizes them -Ronald Reagan Link to comment Share on other sites More sharing options...
greyowl Posted November 5, 2011 Share Posted November 5, 2011 Just finished, not hard at all, I got mine $215 and installed in five minutes once I got over my stupidity Link to comment Share on other sites More sharing options...
NickH Posted June 16, 2012 Share Posted June 16, 2012 I also installed foglamps today and they seemed a bit more involved than I gathered from the instructions, but it's still pretty easy. For starters, I could not get the blank trim pieces off from the front of the bumper with any of my trim tools. I ended up pulling down the splash shield below each section to access the trim (and I needed them down later as well). To drop the shield, I removed two of these: http://i15.photobucket.com/albums/a370/03NHSilvy/Subaru/Foglamps/DSCF0043.jpg I have a special pair of pliers made to remove these but again, a normal pair of needlenose pliers or even 2 flatheads used together will free the center pin. Just pull down on it enough to make the head pop out and then pull the whole pin out. Now the shield can be pulled down. I should also add that even doing this, it was a bit tight and I scratched my hand to hell. Either be ok with this or wear gloves. I recently received my fog light kit...Can you tell me which two of these clips you removed? Just by looking at how many of these clips exist in this area, I can't imagine removing two of them would allow enough room for a hand to fit. Nick Link to comment Share on other sites More sharing options...
mark5032 Posted June 16, 2012 Share Posted June 16, 2012 I was thinking I took out 4 of them per side for extra forearm room. When you get under there it will be obvious which ones need to come out. Link to comment Share on other sites More sharing options...
NickH Posted June 17, 2012 Share Posted June 17, 2012 I was thinking I took out 4 of them per side for extra forearm room. When you get under there it will be obvious which ones need to come out. Ok thanks. Two of them per side didn't make sense for me. Nick Link to comment Share on other sites More sharing options...
pfoyle Posted August 8, 2012 Share Posted August 8, 2012 Great great great writeup! Followed this install (with a couple references to the Subaru install guide that came with the fog lights) and had NO trouble whatsoever! Done in about an hour, with minimal knuckle scraping... Thanks for the writeup! Link to comment Share on other sites More sharing options...
NickH Posted August 12, 2012 Share Posted August 12, 2012 Great great great writeup! Followed this install (with a couple references to the Subaru install guide that came with the fog lights) and had NO trouble whatsoever! Done in about an hour, with minimal knuckle scraping... Thanks for the writeup! I'm glad you found it helpful. Nick Link to comment Share on other sites More sharing options...
ben_alaska Posted September 14, 2012 Share Posted September 14, 2012 Thanks for the guide Nick! I'm replacing one light that snapped off. Found a replacement online for $46.50 from subarupartswarehouse.com. Seems like a cheap fix judging by how much other people are paying for the whole kit. Anyways, the nut seems to be in between 3/8 and 7/16 inch. I need to pick up a metric wrench set. Does anyone remember if you used 10 or 11 mm? I found a cheap set on Amazon that skips 11 mm, will this be okay? Link to comment Share on other sites More sharing options...
MikeNH Posted September 15, 2012 Author Share Posted September 15, 2012 I wrote it. And it says right in my post that the fastener is 10mm. Sent from my iPhone using Tapatalk Government does not solve problems; it subsidizes them -Ronald Reagan Link to comment Share on other sites More sharing options...
ben_alaska Posted September 20, 2012 Share Posted September 20, 2012 Oops, thanks Mike! Link to comment Share on other sites More sharing options...
Jay12Legacy Posted October 5, 2012 Share Posted October 5, 2012 i did this on my 12 legacy in 25 mins in the driveway tonight great write-up been installing them this way for a few years now Jay Link to comment Share on other sites More sharing options...
withoutworry Posted August 13, 2014 Share Posted August 13, 2014 best site to get them? Link to comment Share on other sites More sharing options...
