mkee87 Posted June 26, 2014 Share Posted June 26, 2014 Did a datalog with my accessport, my maf g/s seems real low, my a/f correction is high and I'm knocking bad under boost. Could all of this be attributed to a hole in my turbo inlet hose? I just found one this morning looking around, it's about the size of a pencil. Attached is my datalog, 06 lgt 5eat on cobb acn91 stage 1 https://docs.google.com/spreadsheets/d/1OxrDHur-SW47YkpedfFyw4QNm3KrvhFQvoqXZFIHTMU/edit?usp=sharing Link to comment Share on other sites More sharing options...
700watts Posted June 26, 2014 Share Posted June 26, 2014 in short, yes....and stop boosting until you fix it..or you'll be on the engine rebuild thread next. Link to comment Share on other sites More sharing options...
mkee87 Posted June 26, 2014 Author Share Posted June 26, 2014 I'm running the valet mode map until my new turbo inlet gets here and driving like a grandpa in the meantime. Link to comment Share on other sites More sharing options...
FknBoss Posted June 26, 2014 Share Posted June 26, 2014 If you can access the damaged section put some duct tape to seal it as best as possible to minimize the unmetered air. Link to comment Share on other sites More sharing options...
mkee87 Posted June 26, 2014 Author Share Posted June 26, 2014 Whoever had the car before I bought it tried to patch it with a blob of rtv. Link to comment Share on other sites More sharing options...
compsurge Posted June 26, 2014 Share Posted June 26, 2014 I guess it hasn't blown up so far. That's a terrible fix for a $90 part. Link to comment Share on other sites More sharing options...
mkee87 Posted June 26, 2014 Author Share Posted June 26, 2014 I think I might need a new maf as well. Low g/s numbers and fuel pump duty stuck at 33% Link to comment Share on other sites More sharing options...
compsurge Posted June 26, 2014 Share Posted June 26, 2014 Is everything plugged in? Fix the inlet, then start moving toward other diagnoses. Don't throw money at the problem until you've found the problem. Your inlet is likely the problem. Link to comment Share on other sites More sharing options...
