07spec_b Posted September 23, 2012 Share Posted September 23, 2012 http://imageshack.us/a/img577/4922/174cp.jpg Link to comment Share on other sites More sharing options...
fysics Posted September 24, 2012 Share Posted September 24, 2012 since no one has commented, I'll bite, what are we looking at here? cylinder head? something leaking oil? Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted September 24, 2012 Share Posted September 24, 2012 my guess you are looking at a minimum of a hot-spot on a piston. Chances are you are looking at the top pistion ring, since piston crown is probably broken. would need better pics to be able to tell for sure.. But to anser OPs question.. YES IT IS.. Link to comment Share on other sites More sharing options...
dr_sharp Posted September 24, 2012 Share Posted September 24, 2012 you would have been better off asking a 2nd grader to draw us a picture of it. are you running stock pistons? didn't I just see you run a 12.x @ 115 in the quarter mile thread? lol Link to comment Share on other sites More sharing options...
07spec_b Posted September 24, 2012 Author Share Posted September 24, 2012 That run may of cost me I'm going to try the scope camera again Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted September 24, 2012 Share Posted September 24, 2012 Spark plug get mangled? if so read the "I mangled a spark plug" thread and you'll see all you need Link to comment Share on other sites More sharing options...
InnocentGuns Posted September 25, 2012 Share Posted September 25, 2012 Looks like top ring to me.. hopefully only a bad angle image. good luck Edit: after seeing a larger pic it looks like the recessed areas for the valves blending into the stepped diameter.. Question should be why are you scoping them? Guessing something is wrong.. Link to comment Share on other sites More sharing options...
leggyman17 Posted September 25, 2012 Share Posted September 25, 2012 are you boosting properly? Compression in that cylinder? is it misfiring?? So many questions to answer! Link to comment Share on other sites More sharing options...
07spec_b Posted September 25, 2012 Author Share Posted September 25, 2012 Boost fine compression 130 psi no misfire Some oil consumption need to get another camera as I broke mine Link to comment Share on other sites More sharing options...
Max Capacity Posted September 25, 2012 Share Posted September 25, 2012 Why don't you tell us why your doing this ? Are you using a lot of oil? I was adding about .2qt every few day's, the engine ran fine at 21psi. Never did a compression test, I just got tired of adding oil and replaced the short block. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 25, 2012 Moderators Share Posted September 25, 2012 I just got tired of adding oil and replaced the short block. Love it, lol. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Max Capacity Posted September 25, 2012 Share Posted September 25, 2012 Love it, lol. Isn't that what any sane person would have done...Or did I forget and leave out "in" before sane. LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
07spec_b Posted October 22, 2012 Author Share Posted October 22, 2012 http://imageshack.us/a/img15/3783/img0426li.jpg Found this today now starting a list of parts. Suggestions welcome. Sticking with a 400 horse reliable build. Link to comment Share on other sites More sharing options...
08Legacy08 Posted October 22, 2012 Share Posted October 22, 2012 hone cylinders, drop in wisecos... rods not necessary. I like Wiseco because anti-friction coating AND anti-det grooves on top ring land. The only drop-in piston that gives both. Just my .02 Link to comment Share on other sites More sharing options...
dr_sharp Posted October 22, 2012 Share Posted October 22, 2012 http://imageshack.us/a/img15/3783/img0426li.jpg Found this today now starting a list of parts. Suggestions welcome. Sticking with a 400 horse reliable build. In addition to whatever parts you end up purchasing... get a better tuner. one that won't blow up your pistons. lol Link to comment Share on other sites More sharing options...
07spec_b Posted October 22, 2012 Author Share Posted October 22, 2012 In addition to whatever parts you end up purchasing... get a better tuner. one that won't blow up your pistons. Do you feel that at 25 psi of boost these pistons can be reliable? Link to comment Share on other sites More sharing options...
dr_sharp Posted October 22, 2012 Share Posted October 22, 2012 Do you feel that at 25 psi of boost these pistons can be reliable? Not likely. But there are many other factors to consider besides the boost pressure that your MAP sensor is measuring My first comment was insinuating that your tuner pushed the car further than his capabilities or your cars capabilities. If he pushed the car further than its capabilities, I wouldn't trust him to do it again. If he pushed the tune further than his capabilities, then I wouldn't trust him to do it again. lol Link to comment Share on other sites More sharing options...
07spec_b Posted October 25, 2012 Author Share Posted October 25, 2012 So far I've arrived at this manley pistons head bolts oem gasket kit 11mm oil pump timing belt, water pump, idler, tensioner tgv deletes oil pickup how about cams are they a worthy upgrade? (kelford) Link to comment Share on other sites More sharing options...
dr_sharp Posted October 25, 2012 Share Posted October 25, 2012 that is a solid lineup for 400whp. lol Link to comment Share on other sites More sharing options...
08Legacy08 Posted October 25, 2012 Share Posted October 25, 2012 AFAIK, cams and oversize valves really aren't beneficial unless you want to run higher rpms... Stock cams will def. Support your 400whp Link to comment Share on other sites More sharing options...
Max Capacity Posted October 25, 2012 Share Posted October 25, 2012 I think you mean ARP head studs. They make a block stud kit too. Bigger fuel pump and injectors ? Stock rods ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
07spec_b Posted October 25, 2012 Author Share Posted October 25, 2012 Stock rods Id1000's with walbro Should ask to see if they were arp I got quoted Link to comment Share on other sites More sharing options...
Max Capacity Posted October 25, 2012 Share Posted October 25, 2012 ARP head studs should be a standard with any build. Good insurance. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
07spec_b Posted October 25, 2012 Author Share Posted October 25, 2012 Can cylinders be honed with the crank and connecting rods in? Link to comment Share on other sites More sharing options...
FJuan Posted October 25, 2012 Share Posted October 25, 2012 No, and I wouldn't do it because of all the metal shavings going all over your crank. It's best to do each side seperate, and it makes cleaning them much easier. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
