OutBack Specific Wheel and tire thread
Nightmaresmk
Put your
Wheel specs
Tire size and
Lowering setup or stock
Rub
I'll Start
17x8 et 35 rota torques
255/50R17 Hankook Ventus
Stock
Drivers side front fender wheel slightly on right turns.
http://imageshack.us/a/img27/2269/img20130502083350279.jpg
Edited by Nightmaresmk
Wheels: XXR 527 18x8.75+35
Tires: Pirelli Pzero Nero 245/40/R18
Suspension: ISC Coilovers
Rub/Cut: Cut Rear Metal inner fender no more rub.
Other: Removed Rear bump-stops/helpers
http://farm3.staticflickr.com/2863/8896299338_28a02319e6_h.jpg
http://farm9.staticflickr.com/8407/8896299956_5513fc19a7_h.jpg
Bryan C.
NorCal - SupraLegacy - 05 LGT Wagon 5MT - 15 FXT Premium
Wheels: 17x7.5 50+ Volk CE28
Tires: Falken Sinceras Touring 225/55/17
Suspension: JDM Spec B Rev A Blistien shocks/struts and JDM Spec B Rev A springs
Rub: Zero rub
http://i1250.photobucket.com/albums/hh527/Jimyang/Subaru%20Outback/IMG_7990_zps77d57418.jpg
  • 7 months later...
Wheels:02-03 wrx stockers 16x6.5 (et53 iirc)
Tires: Kumho 225/60/16
Suspension: Stock
Rub/Cut: None
http://i88.photobucket.com/albums/k163/kazantip/SNV31686.jpg
Wheels: No name 18x7.5 +40
Tires: 245/45/18 Micheline alpines
Suspension: Stock
Rub/Cut: None
http://i88.photobucket.com/albums/k163/kazantip/DSC00004.jpg
Wheels: 08-09 Outback XT wheels 17x7or6.5
Tires: 225/55/17
Suspension: Stock springs legacy struts -1"
Rub/Cut: Slight rubbing on bottom of front spring perches
http://i88.photobucket.com/albums/k163/kazantip/CAR014.jpg
Wheels: Drag DR-19 18x7.5 et45
http://lh3.ggpht.com/_9KLQIfKrwMM/TQYT9ADwuiI/AAAAAAAACWk/VYPBpACAu_4/s640/IMG_1225.jpg
Suspension: Ohlin PCV Coilovers
Rub/Cut: None
Other: Cut bump stops in half
http://i88.photobucket.com/albums/k163/kazantip/2012-02-26105954.jpg
Wheels: 08-09 Legacy wheels 17x7or6.5
Tires: 225/55/17
Rub/Cut: None
http://legacygt.com/forums/attachment.php?attachmentid=165267&d=1381761511
  • 2 months later...
Not lowering - going up :) It is an outback after all :D
Wheels: 02 wrx
Tires: 215/70/16 toyo open country ATII
Suspension: Installing this weekend - King Spring rears - 3/4 lift spacers - uprated rear KYB's from primitive and front KYB oe replacements (stock shown)
Rubbing or issues: Zero at stock outback height. Can turn full lock - no rubbing.
http://www.garage1217.com/SUBARU/TIRES%205-3-14/2.JPG
http://www.garage1217.com/SUBARU/TIRES%205-3-14/4.JPG
Edited by garage1217
  • 1 year later...
  • 1 month later...
Wheels: XXR 531 18x8.5+33
Tires: 245/45r18
Suspension: ISC N1 coilovers, -2°F -1°R camber
Fenders: Trimmed, rolled, pulled
http://i489.photobucket.com/albums/rr260/TurboThom/A24E2571-Edit_zps5k4zsdvy.jpg
http://i489.photobucket.com/albums/rr260/TurboThom/A24E2531_zps2dnlagxn.jpg
http://i489.photobucket.com/albums/rr260/TurboThom/A24E2491_zps5gpa71vi.jpg
Wheels: AT Italia Rivas 17x8+35
Tires: 225/55r17 Blizzak WS80
Suspension: ISC N1 coilovers, -1°F -1°R camber
http://i489.photobucket.com/albums/rr260/TurboThom/A24E1631-Edit_zps3hx65xm7.jpg
http://i489.photobucket.com/albums/rr260/TurboThom/A24E1624-Edit_zpsp1ab6ggs.jpg
  • 4 months later...
  • 2 years later...
  • 1 month later...
Are you stock height? if so, 245/45/18 should be fine. You may rub on the inner rear fender liner depending on wheel / tire width.
If lowered all bets are off. I was rubbing with the stock wheels. 235/45/18 is a better choice if you want to be sure of 0 rub.
Edited by Rhitter
It's been a while...currently shopping for tires again after getting a flat.
Koni's - Stock Legacy springs Front & Stock Outback springs Rear
245/45/18 on 18x8.75 +33 Hankook Ventus V12 Evo (about 3 years old)
Fender's rolled and liner trimmed.
Edited by FutureFicus
image embed
  • 2 weeks later...
Yea we spoked before. I've asked a ton of people and seems like the average is 245/40/18x8.5 with no rub (random offsets, no average there but none lower than 44). Haven't heard one with a 235 yet. All depends on offset and how low you go no? 235 is on a 8in wide rim? That would open more rim choices up for sure. Wanted to go as wide as I can obviously which is why I was planning 8.5.
Planning on bc racing coilovers. If you look up Instagram user 6mt_obk thats how low I want to go. Just a nice wheel arch gap all around. He's running 245/40/18x9 et40 with no rub and uncut liners and not rolled. Instagrammer karas_obxt is running 245/40/18x8.5 et44 with only rub in front right because of a nose dive problem(?), Uncut unrolled. Both running bc racing coilovers. Kara's is a bit lower than I'd like.
Stock wheels on a lowered car at et48 definitely sounds like it could rub on the inner tire or maybe at full lock on the fronts
Edited by kaitanium
