Friends car broke down need help figuring out what's wrong.
A friend of mine (member on here) bought my 08 spec.b and is driving it to PA right now. All of a sudden the car lost power when he was cruising on highway and cruise, check engine light came up as well as some other strange light that looks like a plank with a chizle coming at an angle at it. It's a yellow light that I saw before somewhere but never on my car.
He reset the ecu and the car starts now but runs very rough like its only running on 3 cylinders. No lights on the dash.
I am thinking its either a coil pack issues or injector.
Before he drove the car back home he swapped in dw850 used injectors and had the car tunned by a very good and reputable tuner that tuned my car before many times. The car ran great.
So what does that light mean and what could this be?
I can't even find a picture of that light anywhere online.
Lesson should be...if you get a CEL after doing something. Go back over what you messed up.
If it ran fine before you fixed something, and now run's crappy, go back and unfix what you screwed up.
Basic lesson most of us learned at a young age.
Engine Build - Click Here
