Cerebral_1 Posted July 31, 2014 Share Posted July 31, 2014 *MODS: IF THIS IS THE WRONG FORUM FOR THIS THREAD, PLEASE MOVE. The CEL came on recently on my 2005 Subaru Outback XT, and it's throwing the following code: P2021 Intake Manifold Runner Position Sensor/Switch Circuit Low (Bank 2) Given the limited search results on forums and on the internet, it seems to be rather rare for Subarus. After more digging, I'm starting to wonder if it might be related to the TGV sensor (faulty?). The car seems to be running as normal, so I don't think the TGV is stuck open or closed. Any ideas on what the problem/cause likely is? Potential solutions? Link to comment Share on other sites More sharing options...
Underdog Posted July 31, 2014 Share Posted July 31, 2014 It's either in the sensor, the wiring, or the ECU. You could try and find a spare sensor from someone here who has done the TGV delete to see if that fixes it, or you could delete them yourself and then have the codes disabled via opensource. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Corsaro Posted July 31, 2014 Share Posted July 31, 2014 I had the similar P2016. It was intermittent, after reset it sometimes came back straight away other times it lasted a few weeks. Again car was running well. In the end I got fed up with the cruise never working due to the cel and got a cheapo TGV delete (butterflies removed but motors and sensors left in place), together with deleting the codes with romraider. Try cleaning the connectors to the sensor and motor and see if that brings you any luck. Link to comment Share on other sites More sharing options...
Cerebral_1 Posted July 31, 2014 Author Share Posted July 31, 2014 Thanks for the input guys. Been really busy at work this week, so no time to mess with it. Ended up having my buddies at Moore Performance check it out, and it's indeed a faulty TGV sensor, which they're going to just swap out...although I was really tempted to go with a TGV delete Link to comment Share on other sites More sharing options...
