CG_stl Posted September 17, 2014 Share Posted September 17, 2014 I know there are various threads here involving heated mirrors & rear defrosters not working, however none of them have a definitive end point. I recently (on 9/5) purchased an 07 DGM LGT. In the past couple days the temp has dipped (I'm in MO btw) and it has been damp. I press the button for the rear defrost (which as I understand it should also fire the heated mirrors as well), I can hear the relay click, and the climate control indicator turns on. However, the glass is still cool to the touch after being initiated for 30+ minutes. So I have a few questions: Do the mirror indicators light up when powered (amber in color I would guess)? Is the system common ground between the rear and side mirrors? I have tinted windows, I realize it is possible someone pulled a connector when doing it (by the previous owner), could this be the cause of all the frustration I am experiencing? I would like to actually close out this thread with the resolution to my issue. Rather than pointing me to the SubaruTech site for the WD, I would appreciate any input from others with experience first. Thx Link to comment Share on other sites More sharing options...
CG_stl Posted September 18, 2014 Author Share Posted September 18, 2014 Wow, I realize I am a noob here, but expected at least one helpful reply. I pulled the pillar covers in the rear and found that when they installed the tint they managed to break the resistor pack that mounts to the rear window. Anyone have a part number for that part? Link to comment Share on other sites More sharing options...
CG_stl Posted September 25, 2014 Author Share Posted September 25, 2014 For conclusion, I purchased some conductive wire glue from Radioshack: Link Removed Which allowed me to re-attach the tab to the resistor pack. The glue was pretty messy even after kneading it like the comments said. I had to tape the wire in place and allow to dry for 24 hours. I fired it up this morning after 36 hours, and all was well with the rear defrost. The mirrors are working, and as far as I can tell were never not working. Link to comment Share on other sites More sharing options...
Raggamuffin Posted December 2, 2014 Share Posted December 2, 2014 thanks for the info i will look into mine now Link to comment Share on other sites More sharing options...
CG_stl Posted December 3, 2014 Author Share Posted December 3, 2014 Follow up - the glue didn't work. Good news is that I work for an electronics company and I was able to get a wire soldered onto the resistor pack and now all is working well. Link to comment Share on other sites More sharing options...
