scooby600 Posted August 17, 2007 Share Posted August 17, 2007 I have an 08 GT and I put an Invidia catless downpipe on and the CEL came on for a couple hundred miles and then turned off but I went ahead and did the spark plug defouler thing and I used both defoulers. Recently I got a CEL again and it is P2096 and P0420. What am I doing wrong here? I am trying to get rid of these CELs. Link to comment Share on other sites More sharing options...
Legacy05 Posted August 17, 2007 Share Posted August 17, 2007 You will need some sort of engine management, normally when you are able to shut off one code via the CEL Fix, the other code comes on. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted August 17, 2007 Share Posted August 17, 2007 Did you clear the P0420 when the CEL came on the first time? It's extremely unusual to get both the P0420 and P2096 at the same time. Clear both CELs using an OBDII scanner and then remove one of the defoulers (use only one). Link to comment Share on other sites More sharing options...
scooby600 Posted August 17, 2007 Author Share Posted August 17, 2007 I havent cleared any code. It went away on its own the first time. I dont have an OBDII scanner, is there any other way to clear it? Link to comment Share on other sites More sharing options...
mickeyd2005 Posted August 17, 2007 Share Posted August 17, 2007 The light will go out but the code remains in the ecu. You can borrow a OBDII scanner from your local auto parts store for free. That's what I used to do until I bought one on sale for $30. The 07 and 08 are CAN so you need to use a newer OBDII scanner that is CAN compatible. Link to comment Share on other sites More sharing options...
scooby600 Posted August 17, 2007 Author Share Posted August 17, 2007 Is it bad to drive around for a while without doing that? Link to comment Share on other sites More sharing options...
mickeyd2005 Posted August 17, 2007 Share Posted August 17, 2007 I'm not familiar with how the '08 deals with rear O2 sensor failures. Sometimes, if the ecu thinks the rear O2 has failed or is missing, the engine will change the settings to run rich ... all the time. I would clear it and take one of the defoulers out. All it takes is a trip to the auto parts store. Link to comment Share on other sites More sharing options...
scooby600 Posted August 19, 2007 Author Share Posted August 19, 2007 My CEL just turned off by itself again. I'm not really sure what's going on. Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted August 22, 2007 Share Posted August 22, 2007 You will not do any harm. The rear O2 sensor is there just for emissions purposes, it does nothing to adjust AFR. OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
rob-2 Posted April 2, 2013 Share Posted April 2, 2013 Since search works... I want to go catless, run stage 2 and ensure no cell or ECU code. I have a Cobb AP. Will I need to run this defouler and will it prevent a code? Link to comment Share on other sites More sharing options...
