bnguyenbb6 Posted January 11, 2012 Share Posted January 11, 2012 So I finally picked up a real logging cable (lol @ vagcom now) but I'm having a bit of trouble getting the OpenPort 2.0 to read anything from my LC1. I can standalone log to an SD card without the LC1, I can get the LC1 to work with Rom Raider with the tactrix with two different USB ports but I can't get the LC1 to standalone log to an SD card. Does anyone have the correct code for the logcfg.txt file? Thanks in advance. Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted January 14, 2012 Author Share Posted January 14, 2012 Bump. FYI if you are doing wot pulls without a wide band, those logs are pretty useless. Link to comment Share on other sites More sharing options...
itsme Posted February 18, 2012 Share Posted February 18, 2012 Are you using the stereo cable to log the the lc-1? Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted February 18, 2012 Author Share Posted February 18, 2012 Yes, I never got it to work correctly. I have a 2.5mm male to male going directly to the tactrix. I can get the LC1 column to display values but they are 59-60 and don't change very often if at all. Link to comment Share on other sites More sharing options...
