xero287 Posted May 2, 2011 Share Posted May 2, 2011 So, my Invidia DP is currently connected with one spring bolt to the stock midpipe, can't seem to get the other one in. I have the 3-2.5" adapter with the donut in and I thought it was necessary to have the spring bolts for the donut. My question is: Can I just use the bolt and nut from the spring bolt w/o the spring, and if not where can I buy a longer spring bolt. I tried searching, but it seems like most manufacturers either don't sell them alone or are discontinued. TIA Link to comment Share on other sites More sharing options...
cabin Posted May 2, 2011 Share Posted May 2, 2011 Put the spring in a vise and put 2 zip-ties through the coils. As you compress the spring, snug the zip-ties down. This should get you enough slack to get the nut started. Once you get the nut started a couple turns, cut the zip-ties and pull them out. This method worked great for me the other day. Link to comment Share on other sites More sharing options...
Drift Motion Posted May 2, 2011 Share Posted May 2, 2011 Put the spring in a vise and put 2 zip-ties through the coils. As you compress the spring, snug the zip-ties down. This should get you enough slack to get the nut started. Once you get the nut started a couple turns, cut the zip-ties and pull them out. This method worked great for me the other day. that's some awesome info right there! Link to comment Share on other sites More sharing options...
xero287 Posted May 2, 2011 Author Share Posted May 2, 2011 Oh wow, that sounds like a great idea! Thanks. Link to comment Share on other sites More sharing options...
mwiener2 Posted May 2, 2011 Share Posted May 2, 2011 The spring bolt is meant to replaced with a standard bolt when you use that adapter. Snug it all down good and tight, but don't destroy the donut gasket in the process. I like the zip-tie thing. I gonna try that. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
xero287 Posted May 2, 2011 Author Share Posted May 2, 2011 Isn't it supposed to flex somewhat though? Link to comment Share on other sites More sharing options...
mwiener2 Posted May 2, 2011 Share Posted May 2, 2011 The catback that goes with that 3" downpipe doesn't flex at that joint. If you let flex, it will leak. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
xero287 Posted May 2, 2011 Author Share Posted May 2, 2011 Hmmm, so...if I eventually get a 3 inch midpipe that'll just be a direct install with no donut or adapter correct? And I'd just use bolts instead of the spring bolts right? Link to comment Share on other sites More sharing options...
xero287 Posted May 2, 2011 Author Share Posted May 2, 2011 So, spring bolts arent necessary at all then right? can I just use the same bolts without the spring? Link to comment Share on other sites More sharing options...
mwiener2 Posted May 3, 2011 Share Posted May 3, 2011 Hmmm, so...if I eventually get a 3 inch midpipe that'll just be a direct install with no donut or adapter correct? And I'd just use bolts instead of the spring bolts right? Your aftermarket downpipe replaces the factory down and mid pipe. Unless you bought a 2-piece aftermarket downpipe, there are a few out there. You would need to get a matching catback. Just use regular bolts with a flat gasket. So, spring bolts arent necessary at all then right? can I just use the same bolts without the spring? You'll probably run out of threads before it became tight if you use the spring bolts without the springs. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
xero287 Posted May 3, 2011 Author Share Posted May 3, 2011 Hmm, thanks for the very helpful info. I'll just go to home depot and pick up some bolts tomorrow. I can cancel my appt with subaru to put in the spring bolt then lol. I got one in but the other one refuses. Link to comment Share on other sites More sharing options...
mwiener2 Posted May 3, 2011 Share Posted May 3, 2011 Just for the sake of posting.... there are aftermakret springbolt kits. Vibrant makes some. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
xero287 Posted May 3, 2011 Author Share Posted May 3, 2011 https://www.dwperformance.com/Pages/ItemProfile_Detail.aspx?ItemProfileId=VIB10112 Isnt the diameter too small?? Link to comment Share on other sites More sharing options...
mwiener2 Posted May 3, 2011 Share Posted May 3, 2011 i never measured.. they also make a few different kits My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
xero287 Posted May 3, 2011 Author Share Posted May 3, 2011 Just cut the spring in half I'll try that tomorrow. Link to comment Share on other sites More sharing options...
spec.B Dream Posted May 3, 2011 Share Posted May 3, 2011 I cut my springs when using the adapter. I maybe cut a quarter off. I didn't cut half because I didn't want to have problems if I ever wanted to swap back to the stock exhaust. Link to comment Share on other sites More sharing options...
xero287 Posted May 3, 2011 Author Share Posted May 3, 2011 I figure I can just buy the springs if I do need to revert to stock Link to comment Share on other sites More sharing options...
ibr_adam09 Posted May 3, 2011 Share Posted May 3, 2011 My thread shall prevail http://legacygt.com/forums/showthread.php/3-2-5-adapter-exhaust-springs-bolt-solution-156515.html?t=156515 Link to comment Share on other sites More sharing options...
xero287 Posted May 3, 2011 Author Share Posted May 3, 2011 Lol, that's exactly what I did. Is it supposed to be quite loud? lol Link to comment Share on other sites More sharing options...
