BryanBNR Posted March 9, 2011 Share Posted March 9, 2011 Hello all. Here are pictures of the first VF54 turbocharger upgrade. Also included are turbine wheel and compressor wheel pictures to compare stock vs. upgraded compressor/turbine wheels. This is an HTA68 version that is matched with a TD05H turbine wheel. Both VF54 end housings are machined to fit the TD05 center section. This unit was balanced below .4 gram/in2! Glad to finally offer this to the newest generation of LGTs! Bryan Nickell BNR Supercars LLC 205 640 1193 BNRsupercars@yahoo.com www.BNRsupercars.com Link to comment Share on other sites More sharing options...
SuBiElOvEr Posted March 9, 2011 Share Posted March 9, 2011 http://legacygt.com/forums/showthread.php/stage-4-and-quest-more-hp-begins-today-156003.html Link to comment Share on other sites More sharing options...
EFI Logics Posted March 9, 2011 Share Posted March 9, 2011 Bryan - Excellent work! We can't wait to get this in and see the results. - Chris Link to comment Share on other sites More sharing options...
dnotarangelo Posted March 9, 2011 Share Posted March 9, 2011 Great! Pricing? Link to comment Share on other sites More sharing options...
BryanBNR Posted March 9, 2011 Author Share Posted March 9, 2011 $200 over the VF40 upgrades that I offer. Plus I need core up front. $925 EVO/TD05H $975 18G/TD05H $1025 20G/TD05H $1175 HTA/TD05H No available options for TD06/20G. Bryan@BNR 205 640 1193 Link to comment Share on other sites More sharing options...
GTTuner Posted March 9, 2011 Share Posted March 9, 2011 You guys rock man. Nice work, can't wait to see some results. Link to comment Share on other sites More sharing options...
TiredGXP Posted March 9, 2011 Share Posted March 9, 2011 I've grown accustomed to having 16 lbs by 3000 RPM. Will be watching the other thread to see how the HTA86/TD05 spools up in the low mount location - really hoping to see 2-300 difference from the boost response in the Gen IVs. Bryan - any particular oil/water plumbing bits needed, or is this a direct bolt in upgrade? Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted March 9, 2011 Share Posted March 9, 2011 Very nice. Very nice stuff. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted March 9, 2011 Share Posted March 9, 2011 Wow BnR does it AGAIN! Way to go B, bringing power to the people! Link to comment Share on other sites More sharing options...
cryo Posted March 10, 2011 Share Posted March 10, 2011 Thanks for what you have done for the legacy gt community. Most overlook us unless it fits a wrx too. you are the man. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
ttboy19 Posted March 10, 2011 Share Posted March 10, 2011 subscribe Link to comment Share on other sites More sharing options...
sixspeedlegacy Posted March 10, 2011 Share Posted March 10, 2011 This is excellent, I'm really excited to see the results. I have to imagine 400wtq will be possible with the HTA68, if it comes at 3200rpms that would be epic. Ben Link to comment Share on other sites More sharing options...
BryanBNR Posted March 10, 2011 Author Share Posted March 10, 2011 Thanks everyone. I appreciate your business! Factory oil drain tube, both water lines/water banjo bolts, oil supply banjo bolt are all are usable on this turbocharger upgrade. As for 400 Ft/lbs you have to run lots of boost to get that out of the 2.5. This unit is fitted with the stock actuator because he wants 20 psi. If he wanted 22 psi or more, I would have put an upgraded actuator in its place. I don't see a problem with this turbo making full boost in the 2000's. Bryan@BNR 205 640 1193 www.BNRsupercars.com Link to comment Share on other sites More sharing options...
acumenhokie Posted March 10, 2011 Share Posted March 10, 2011 Let me ask some newb questions (I've owned a turbo car for all of a month and a half now). With this upgrade to the turbo do you have to move to the FMIC like SuBiElOvEr did with hisor could you stay with the top mount? Is an IC change/upgrade required? What other components would need upgraded (likely the clutch? what about injectors or fuel)? Sorry if these are dumb questions but like I said I'm a newb. Link to comment Share on other sites More sharing options...
minuccims Posted March 10, 2011 Share Posted March 10, 2011 Here are just my thoughts in this ....You could upgrade the turbo with the top mount IC. Consider the following would be required to support the increse in HP: - Assuming you're at Stage II - Better Clutch - Bigger Fuel Pump - Bigger Injectors - Also consider the plastic caps of the TMIC may need to be stenghtened so they do not fail Link to comment Share on other sites More sharing options...
BryanBNR Posted March 10, 2011 Author Share Posted March 10, 2011 This is a direct fitment turbocharger upgrade. No fabrication required. If you want to stay with stock fuel injectors/pump or if you have an automatic transmission, the evo 16G is the way to go. If you plan on a fuel system upgrade (injectors/pump), then I would step up to the 18G minimum. If you want more of an aggressive car, then do the HTA or the 20G. Bryan@BNR 205 640 1193 www.BNRsupercars.com Link to comment Share on other sites More sharing options...
TiredGXP Posted March 10, 2011 Share Posted March 10, 2011 This is a direct fitment turbocharger upgrade. No fabrication required. If you want to stay with stock fuel injectors/pump or if you have an automatic transmission, the evo 16G is the way to go. If you plan on a fuel system upgrade (injectors/pump), then I would step up to the 18G minimum. If you want more of an aggressive car, then do the HTA or the 20G. Bryan@BNR 205 640 1193 www.BNRsupercars.com Thanks Bryan, this makes sense. Stock turbo pretty much maxes the stock injectors, so I'm thinking 650 injectors will be required for the 18G/TD05 at 20psi on pump gas. With the proper supporting mods, that turbo ought to provide 300-320 to the wheels without being on the jagged edge. Sounds just about perfect for my DD needs. Link to comment Share on other sites More sharing options...
minuccims Posted March 18, 2011 Share Posted March 18, 2011 Bryan - Incredible results. Congrats. Thanks for taking on the turbo mod. Link to comment Share on other sites More sharing options...
Legend Posted March 18, 2011 Share Posted March 18, 2011 Congrats Bryan. Great products and way to stay on TOP of the game. The '10 dyno looks fantastic! My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
_MFB_ Posted March 29, 2013 Share Posted March 29, 2013 Any updates on this since 2011? Link to comment Share on other sites More sharing options...
acumenhokie Posted March 29, 2013 Share Posted March 29, 2013 What info are you looking for? My turbo is at BNR awaiting 20G upgrade. Link to comment Share on other sites More sharing options...
islandborn Posted March 29, 2013 Share Posted March 29, 2013 I sit with Bryan's 18G. I freaking love it. yes I upgraded the inject and fuel pump too. But it is a direct bolt on. And yes, I will be needing a clutch soon. Link to comment Share on other sites More sharing options...
islandborn Posted March 29, 2013 Share Posted March 29, 2013 Oh! Bryan, question: People ask me - what is my Hotside? Do you remember what you did with mine? It was the billet 18G. Link to comment Share on other sites More sharing options...
aerophool Posted March 29, 2013 Share Posted March 29, 2013 Please let me know how the 20G treats you. I was on the phone with Bryan about an upgrade on Wednesday. I have an extra VF54 sitting here. I haven't yet decided on 18g or 20g. Current Mileage as of 19-June-15: 15012 Purchase Date: 30-June-12 Visit my profile page (visitor message section) for a brief mod. list. Link to comment Share on other sites More sharing options...
s2baru Posted March 29, 2013 Share Posted March 29, 2013 Go big or go home! Shoot for the HTA Link to comment Share on other sites More sharing options...
