TheBlubaru Posted June 24, 2012 Share Posted June 24, 2012 After installing my perrin tmic today I noticed my car won't boost past 10psi. I checked for leaks everywhere but couldn't find any I even bought one of those Mr gaskets for the turbo side. Does it have anything to do with the fact that I have an ots tune? The car currently has a stage 2 ots Cobb tune with a Cobb catless dp catless up and Cobb catback. God created turbo lag to give V8s a chance Link to comment Share on other sites More sharing options...
ibr_adam09 Posted June 24, 2012 Share Posted June 24, 2012 Did you check around the tb hose ? cel light on ? Link to comment Share on other sites More sharing options...
jasejase Posted June 24, 2012 Share Posted June 24, 2012 Doesn't sound like the tmic alone would cause that issue. Check your hoses again. Boost leak tester would come in Handy. Link to comment Share on other sites More sharing options...
TheBlubaru Posted June 24, 2012 Author Share Posted June 24, 2012 No leak around the TB hose it's on as tight as could be and no lights on. yea I've been meaning to pick one of those up but haven't gotten around to it. God created turbo lag to give V8s a chance Link to comment Share on other sites More sharing options...
jasejase Posted June 24, 2012 Share Posted June 24, 2012 Cel? What psi were u pre tmic swap? Link to comment Share on other sites More sharing options...
ibr_adam09 Posted June 24, 2012 Share Posted June 24, 2012 Maf unplugged ? I could only think the car is in limp mode and only using waste gate pressure. Link to comment Share on other sites More sharing options...
TheBlubaru Posted June 24, 2012 Author Share Posted June 24, 2012 Pre TMIC install I was at 15. Wouldn't an unplugged MAF throw a CEL code though? God created turbo lag to give V8s a chance Link to comment Share on other sites More sharing options...
No DRFT Posted June 24, 2012 Share Posted June 24, 2012 Check for leaks again and reset ecu. I have no control over drippie. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted June 24, 2012 Share Posted June 24, 2012 Pre TMIC install I was at 15. Wouldn't an unplugged MAF throw a CEL code though? Sometimes it won't for the first few miles. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 24, 2012 Share Posted June 24, 2012 If you have a air compressor you can plug the hose off the air cleaner box with a pint size paint can, then pull the hose off the BOV and give it a quick blast of air. Put your thumb over the hose and listen for leaks. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
TheBlubaru Posted June 24, 2012 Author Share Posted June 24, 2012 Good call no drft I reset the ecu and boost is right back up to 15. Now a rattle has developed under wot though. I thought at first it was the turbo heat shield but its on tight. God created turbo lag to give V8s a chance Link to comment Share on other sites More sharing options...
ibr_adam09 Posted June 26, 2012 Share Posted June 26, 2012 The car might have been in limp mode for some reason . IE. bad gas Link to comment Share on other sites More sharing options...
m sprank Posted June 26, 2012 Share Posted June 26, 2012 Could be false knock too. Is the TMIC touching the clutch master cylinder res (MT only)? Link to comment Share on other sites More sharing options...
rtbrjason Posted June 27, 2012 Share Posted June 27, 2012 Post a Learning View? Link to comment Share on other sites More sharing options...
TheBlubaru Posted June 27, 2012 Author Share Posted June 27, 2012 It is rubbing against the CMC reservoir a little bit. I talked to Perrin and they are sending me a spacer. What is false knock? God created turbo lag to give V8s a chance Link to comment Share on other sites More sharing options...
ibr_adam09 Posted June 27, 2012 Share Posted June 27, 2012 Vibrations around the motor that the knock sensor picks up and try's to correct it . Link to comment Share on other sites More sharing options...
rtbrjason Posted June 27, 2012 Share Posted June 27, 2012 It is rubbing against the CMC reservoir a little bit. I talked to Perrin and they are sending me a spacer. What is false knock? False knock is when the knock sensor picks up noise other than actual knock. The knock sensor is just a small mic essentially tuned to pick up a certain frequency range of sound. You'd be surprised though at how much stuff can be rattling around in the engine bay and the knock sensor won't pick it up though. When I had my long block dealer replaced they left all kinds of loose shields and bolts etc. I fixed a ton of rattles and loose shields and had no notable difference in knock sum. Link to comment Share on other sites More sharing options...
jasejase Posted June 27, 2012 Share Posted June 27, 2012 My perrin rubs my CMC (not all the time, usually at first gear take offs, more so when it's cold)... Havent received any false knock to date... knock on wood. The spacer's been sitting in my garage for 2 months or so now. lol Need to get that taken care of. Link to comment Share on other sites More sharing options...
m sprank Posted June 27, 2012 Share Posted June 27, 2012 Knock sensor is right under throttle body. So, very close to MCR which the Perrin tends to rub. Link to comment Share on other sites More sharing options...
jasejase Posted June 27, 2012 Share Posted June 27, 2012 Noted... Always wondered where the knock sensor was. Link to comment Share on other sites More sharing options...
m sprank Posted June 27, 2012 Share Posted June 27, 2012 about the size of a nickel. single bolt through the center. pigtail wire that connects next to the pitch stop. pigtail is angled at approx 10-11 o'clock when facing the firewall. Link to comment Share on other sites More sharing options...
